[Bio] / smc / Makefile Repository:
Log of /smc/Makefile
Fri Sep 26 19:36:17 2003 UTC (16 years, 1 month ago) by park
CVS Tags: HEAD
Extend to generate Python statemachines.
   o  smc  < foo.sm   makes c++
   o  smc -c < foo.sm makes c++
   o  smc -p < foo.sm makes python
The yacc is written (originally) to call GenStateMap when the
end of the document is hit.  We make GenStateMap call
generator which is a ptr to function.  We set the fn
to call in main via command line opts.
Thu Aug 21 17:00:03 2003 UTC (16 years, 3 months ago) by efrank
Branch: oma-04Jun1993
CVS Tags: anl000
Diff to previous 1.1 , to next main 1.2
State machine compiler from Bob Marting (R. C. Martin) at Object Mentor Associates.
Has a few small compilation fixes.
We have this code without explicit permission.  We ar evaluating extensions.
Do not distribute..but I think we're consistent with its usage requirements
Branch point for: oma-04Jun1993
