[Bio] / askkb / service / process.tt Repository:
Log of /askkb/service/process.tt
Wed May 1 00:43:17 2013 UTC (6 years, 7 months ago) by brettin
CVS Tags: HEAD
 changed use of kb_service_name to kb_service_dir when in dir context
Wed Apr 24 16:11:59 2013 UTC (6 years, 7 months ago) by olson
Add KBase module skeleton
