[Bio] / askkb / deploy.cfg Repository:
Log of /askkb/deploy.cfg
Revision 1.4 - (view) (download) (annotate) - [selected]
Thu May 16 16:08:21 2013 UTC (6 years, 6 months ago) by brettin
CVS Tags: HEAD
fixed syntax error in format, had to add an = sign.
Wed May 1 05:00:40 2013 UTC (6 years, 7 months ago) by brettin
fixed typo askdb shoudl be askkb
Wed May 1 04:15:32 2013 UTC (6 years, 7 months ago) by brettin
decided to put help_dir and prlog_dir directly under services/askkb so we don't have to worry about creating a help dir and prolog dir
Wed May 1 00:54:03 2013 UTC (6 years, 7 months ago) by brettin
Diff to selected 1.4
new file
