[Bio] / askkb / Makefile Repository:
Log of /askkb/Makefile
Links to MAIN: (view) (download) (annotate)
Thu May 16 18:06:17 2013 UTC (6 years, 6 months ago) by brettin
CVS Tags: HEAD
Changed deploy-doc target to include copying the Help directory out of doc/
Wed May 1 04:16:35 2013 UTC (6 years, 7 months ago) by brettin
added creation of symlink under Help directory and added deployment of Help files and prolog file
Wed May 1 00:45:43 2013 UTC (6 years, 7 months ago) by brettin
Changes since 1.1: +19 -12 lines
 introduced the SERVICE_DIR variable so the service directory and service name can be different
Wed Apr 24 16:11:58 2013 UTC (6 years, 7 months ago) by olson
Add KBase module skeleton
