[Bio] / WebApplication / WikiShim.pm Repository:
Log of /WebApplication/WikiShim.pm
Wed Apr 22 23:23:31 2009 UTC (10 years, 7 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.5: +4 -1 lines
Fixed to fully specify the web-app-backend connection data.
Fri Oct 17 16:35:08 2008 UTC (11 years, 1 month ago) by parrello
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26
Changes since 1.4: +2 -1 lines
Added default page support.
Wed Oct 15 11:39:49 2008 UTC (11 years, 2 months ago) by parrello
Changed to specify an empty string for the default page. This prevents a run-time warning.
Tue Sep 16 18:55:59 2008 UTC (11 years, 2 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
Changes since 1.2: +6 -32 lines
Changed to turn on tracing before creating the WebApplication object.
Thu Sep 4 19:01:08 2008 UTC (11 years, 3 months ago) by parrello
Changed to move the NMPDR style overrides to the end of the style list instead of the beginning.
Wed Sep 3 20:25:06 2008 UTC (11 years, 3 months ago) by parrello
Bridging object used to embed NMPDR scripts in the wiki.
