[Bio] / WebApplication / WebPage / UserManagement.pm Repository:
Log of /WebApplication/WebPage/UserManagement.pm
Thu Jun 21 20:28:47 2018 UTC (2 years ago) by gdpusch
CVS Tags: HEAD
Changes since 1.6: +30 -2 lines
Added a "Impersonate User" button to the "edit user" display to make it easier to select a specific user. (The "Impersonate User" popup list on the Account-management page has become virtually unusable now that there are 35,000 users. :-(
Wed Oct 15 14:13:39 2008 UTC (11 years, 9 months ago) by paczian
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.5: +10 -1 lines
user details will now include the organization, which will be a link to the organization page
Wed Sep 3 21:01:25 2008 UTC (11 years, 10 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
Converted URLs.
Mon Feb 11 16:59:43 2008 UTC (12 years, 5 months ago) by paczian
Changes since 1.3: +9 -9 lines
removed login changeability
Fri Feb 8 16:54:58 2008 UTC (12 years, 5 months ago) by paczian
Changes since 1.2: +37 -2 lines
overhaul of vis
added group information to AccountManagement
Fri Jan 25 20:32:22 2008 UTC (12 years, 5 months ago) by paczian
logical and visual upgrades
Wed Jan 23 21:05:53 2008 UTC (12 years, 5 months ago) by paczian
initial version
