[Bio] / WebApplication / WebPage / TermsofService.pm Repository:
Log of /WebApplication/WebPage/TermsofService.pm
Tue Mar 8 18:50:49 2011 UTC (9 years, 3 months ago) by paczian
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.8: +4 -4 lines
fixed bracket bug
Tue Mar 8 18:39:57 2011 UTC (9 years, 3 months ago) by paczian
Changes since 1.7: +37 -33 lines
fixed thing with previous
Tue Mar 8 18:30:59 2011 UTC (9 years, 3 months ago) by paczian
Changes since 1.6: +0 -1 lines
removed unsuited paragraph
Tue Mar 8 12:56:53 2011 UTC (9 years, 3 months ago) by paczian
Changes since 1.5: +20 -2 lines
added funding sources
Tue Mar 8 09:48:01 2011 UTC (9 years, 3 months ago) by paczian
fixed version checking
Tue Mar 8 09:45:02 2011 UTC (9 years, 3 months ago) by paczian
Changes since 1.3: +50 -22 lines
added version 2
Thu Jul 9 10:42:19 2009 UTC (10 years, 11 months ago) by paczian
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, myrast_33, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
fixed redirect
Fri Jun 12 10:34:00 2009 UTC (11 years ago) by paczian
Changes since 1.1: +47 -1 lines
incorporated terms of service
Thu Jun 11 21:52:54 2009 UTC (11 years ago) by jared
initial version
