[Bio] / WebApplication / WebPage / Register.pm Repository:
Log of /WebApplication/WebPage/Register.pm
Mon Jun 13 09:35:45 2011 UTC (9 years, 1 month ago) by paczian
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.9: +5 -3 lines
updated text
Mon Mar 8 14:49:59 2010 UTC (10 years, 4 months ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.8: +2 -2 lines
Text tweak to make it more clear that account approval is not automatic.
Tue Apr 29 21:07:53 2008 UTC (12 years, 2 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_release_2008_09_29
Changes since 1.7: +3 -1 lines
Added a TITLE statement to prevent a wiki naming conflict.
Thu Feb 28 21:03:18 2008 UTC (12 years, 4 months ago) by paczian
CVS Tags: rast_rel_2008_04_23
Changes since 1.6: +5 -5 lines
updated informational text
Fri Feb 8 20:02:42 2008 UTC (12 years, 5 months ago) by paczian
opened h1, closed h2... fixed
Tue Jan 29 17:29:26 2008 UTC (12 years, 5 months ago) by paczian
Changes since 1.4: +3 -3 lines
disambigued text for already registered users
Fri Oct 26 20:00:19 2007 UTC (12 years, 8 months ago) by paczian
added group information
Fri Aug 10 17:43:06 2007 UTC (12 years, 11 months ago) by paarmann
Changes since 1.2: +9 -2 lines
added text
Thu Jul 5 20:38:43 2007 UTC (13 years ago) by paczian
Changes since 1.1: +5 -1 lines
added supported_rights method
Fri Apr 27 15:58:09 2007 UTC (13 years, 2 months ago) by paczian
initial version
