[Bio] / WebApplication / WebPage / PrivateOrganismPreferences.pm Repository:
Log of /WebApplication/WebPage/PrivateOrganismPreferences.pm
Sat Jul 23 19:37:41 2016 UTC (3 years, 6 months ago) by gdpusch
CVS Tags: HEAD
Changes since 1.14: +4 -1 lines
Added genome-ID-pair tooltips to job-status cells to increase readability of large job-status arrays.
Fri Jul 22 16:56:55 2016 UTC (3 years, 6 months ago) by gdpusch
Changes since 1.13: +1 -0 lines
Increased size of selection box to 15 lines.
Tue Jul 29 18:50:39 2014 UTC (5 years, 6 months ago) by olson
CVS Tags: rast_rel_2014_0912
Show candidates latest-first.
Tue Jul 29 16:47:57 2014 UTC (5 years, 6 months ago) by olson
CVS Tags: rast_rel_2014_0729
Changes since 1.11: +32 -9 lines
Fix peer org group manipulation error.
Tue Oct 5 11:40:02 2010 UTC (9 years, 3 months ago) by paczian
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.10: +35 -32 lines
massive speedup to previous version
Tue Jun 2 11:09:25 2009 UTC (10 years, 7 months ago) by paczian
CVS Tags: rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.9: +5 -3 lines
creating sim dir if missing
Tue Jun 2 10:55:15 2009 UTC (10 years, 7 months ago) by paczian
Changes since 1.8: +4 -4 lines
fixed bug if there is no sims directory
Thu May 28 09:16:30 2009 UTC (10 years, 8 months ago) by paczian
now getting only viewable jobs
Fri Mar 13 13:56:25 2009 UTC (10 years, 10 months ago) by paczian
Changes since 1.6: +24 -1 lines
improved speed of requirement checking
Fri Dec 12 11:19:00 2008 UTC (11 years, 1 month ago) by paczian
CVS Tags: rast_rel_2008_12_18, rast_rel_2009_02_05
Changes since 1.5: +7 -1 lines
fixed error on rast orgs in preference but not on server
Fri Nov 21 14:15:47 2008 UTC (11 years, 2 months ago) by paczian
CVS Tags: rast_rel_2008_11_24
Changes since 1.4: +7 -7 lines
changed jobs_for_user to jobs_for_user_fast
Thu Nov 20 15:46:15 2008 UTC (11 years, 2 months ago) by paczian
Changes since 1.3: +1 -2 lines
adjusted for Preferences to use view right
removed sorting of joblist
switched to use job_for_user_fast
Mon Nov 10 22:52:32 2008 UTC (11 years, 2 months ago) by olson
sort list by job id
Mon Nov 10 22:27:22 2008 UTC (11 years, 2 months ago) by olson
Changes since 1.1: +36 -5 lines
more error checking
Mon Nov 3 16:01:12 2008 UTC (11 years, 2 months ago) by paczian
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2
initial version
shows and allows to change the peer group selection for private organisms
