[Bio] / WebApplication / WebPage / ManagePreferences.pm Repository:
Log of /WebApplication/WebPage/ManagePreferences.pm
Fri Nov 15 05:44:56 2013 UTC (6 years, 2 months ago) by seaver
Diff to previous 1.20
Updated default preference of 4 genomes in CompareRegion to 15 genomes to enable plant genomes to show bacterial genomes in CompareRegions
Thu Aug 16 17:15:28 2012 UTC (7 years, 5 months ago) by gdpusch
Changes since 1.19: +25 -28 lines
Diff to previous 1.19
Resolved conflict between 1.18 and 1.19.
Mon Jul 2 18:26:10 2012 UTC (7 years, 6 months ago) by seaver
Changes since 1.18: +23 -65 lines
Diff to previous 1.18
Merging conflict
Wed May 23 15:28:28 2012 UTC (7 years, 8 months ago) by paczian
CVS Tags: mgrast_version_3_2, mobedac_release_05302012
Changes since 1.17: +19 -3 lines
Diff to previous 1.17
webkeys are now instantly stored
Fri Dec 2 19:15:47 2011 UTC (8 years, 1 month ago) by tharriso
CVS Tags: mgrast_dev_12152011, mgrast_release_3_1_2
Changes since 1.16: +52 -16 lines
Diff to previous 1.16
stuff tobi did
Fri Sep 16 09:08:46 2011 UTC (8 years, 4 months ago) by paczian
CVS Tags: mgrast_dev_10262011, rast_rel_2011_0928
added RNASEQRAST with same options as MGRAST
Fri Sep 16 09:07:44 2011 UTC (8 years, 4 months ago) by paczian
Changes since 1.14: +7 -1 lines
added webservicekey to mgrast
Tue Jul 12 09:17:34 2011 UTC (8 years, 6 months ago) by paczian
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_1
Changes since 1.13: +45 -9 lines
added option for multiple entries for a single preference
added switch for mgrast
removed dependency (moved to if statement)
Thu Jun 30 19:56:27 2011 UTC (8 years, 7 months ago) by parrello
Changes since 1.12: +1 -0 lines
Changed to new annotation security model.
Thu Jun 30 19:41:45 2011 UTC (8 years, 7 months ago) by parrello
Thu May 26 16:53:38 2011 UTC (8 years, 8 months ago) by olson
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_1_0
Changes since 1.10: +5 -0 lines
Add a RAST admin preference AdminStartingJob that limits the jobs returned by get_jobs_for_user_fast() to
start with the given job, if it is set.
Wed May 25 19:58:08 2011 UTC (8 years, 8 months ago) by devoid
Allowing non-annotators to change the Feature alias display preference.
Fri Feb 4 20:43:56 2011 UTC (8 years, 11 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.8: +13 -0 lines
Add support for admin preference that keeps all jobs from showing up.
Tue Jun 23 10:24:10 2009 UTC (10 years, 7 months ago) by paczian
CVS Tags: rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
added preference to show the alias column in the feature table
Mon Jun 22 15:06:56 2009 UTC (10 years, 7 months ago) by paczian
Changes since 1.6: +6 -0 lines
added preference option for annotators to display aux roles on the annotation page
Mon Jun 8 15:45:33 2009 UTC (10 years, 7 months ago) by paczian
Changes since 1.5: +6 -0 lines
added preference for ss editor
Thu Apr 9 11:48:18 2009 UTC (10 years, 9 months ago) by paczian
CVS Tags: rast_rel_2009_05_18
Changes since 1.4: +7 -1 lines
added info option for preferences
added info to WebServices preference
Tue Apr 7 17:47:16 2009 UTC (10 years, 9 months ago) by paczian
Changes since 1.3: +47 -1 lines
added WebServices authentication
Fri Mar 27 17:10:40 2009 UTC (10 years, 10 months ago) by paczian
fixed determination of annotator status
Fri Mar 27 10:53:56 2009 UTC (10 years, 10 months ago) by paczian
Changes since 1.1: +20 -1 lines
added option for annotators to show alias information
Wed Jan 21 15:01:11 2009 UTC (11 years ago) by paczian
initial version
page to change the preferences of a user
