[Bio] / WebApplication / WebPage / AlignSeqsClustal.pm Repository:
Log of /WebApplication/WebPage/AlignSeqsClustal.pm
Links to mgrast_dev_02212011: (view) (download) (as text) (annotate)
Fri Mar 20 14:37:17 2009 UTC (11 years ago) by bartels
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.3: +9 -0 lines
Tue Mar 17 13:46:32 2009 UTC (11 years ago) by bartels
Changes since 1.2: +61 -4 lines
javascript now inside
Fri Mar 13 11:28:28 2009 UTC (11 years ago) by bartels
Changes since 1.1: +15 -4 lines
added the option to give a downstream regions with the options
seq_format=pre
firstpoint=\d+
secondpoint=[+-]\d+
Thu Mar 5 13:02:55 2009 UTC (11 years, 1 month ago) by bartels
