[Bio] / WebApplication / WebPage.pm Repository:
Log of /WebApplication/WebPage.pm
Fri Feb 18 18:30:19 2011 UTC (8 years, 9 months ago) by devoid
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.29: +54 -0 lines
Diff to previous 1.29
Implementing changes to WebApp for require_javascript_ordered() and require_css_ordered() calls.
Sun Jan 30 17:41:18 2011 UTC (8 years, 10 months ago) by redwards
CVS Tags: myrast_33
Changes since 1.28: +6 -5 lines
Diff to previous 1.28
correcting a hidden call that didnt work with apostrophes
Thu Jun 17 18:23:26 2010 UTC (9 years, 5 months ago) by olson
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Diff to previous 1.27
fix defined check to use defined, not value.
Mon Jun 14 09:23:06 2010 UTC (9 years, 5 months ago) by paczian
Changes since 1.26: +2 -0 lines
Diff to previous 1.26
checking for undefined value in CGI key-value hash passed to start_form
Wed Sep 3 21:01:14 2008 UTC (11 years, 3 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_release_2008_09_29
Changes since 1.25: +29 -0 lines
Diff to previous 1.25
Converted URLs.
Mon Apr 14 17:18:02 2008 UTC (11 years, 7 months ago) by paczian
Changes since 1.24: +14 -0 lines
Diff to previous 1.24
now has a default method robot_content which will return special content show only to Googlebot
Sun Mar 23 16:38:37 2008 UTC (11 years, 8 months ago) by parrello
Diff to previous 1.23
Fixed a POD error.
Fri Mar 21 20:12:38 2008 UTC (11 years, 8 months ago) by paczian
Changes since 1.22: +4 -4 lines
Diff to previous 1.22
removed die upon retrieving unknown id (prohibited checking for existance of id in webpage)
Mon Feb 25 22:17:31 2008 UTC (11 years, 9 months ago) by paczian
Changes since 1.21: +3 -5 lines
Diff to previous 1.21
fixed regexp for name function
Fri Feb 15 21:26:21 2008 UTC (11 years, 9 months ago) by paczian
Changes since 1.20: +6 -3 lines
Diff to previous 1.20
updated POD documentation for start form
Wed Jan 16 21:32:14 2008 UTC (11 years, 10 months ago) by paarmann
Changes since 1.19: +0 -6 lines
Diff to previous 1.19
removed unused use statements
Mon Jan 14 16:27:24 2008 UTC (11 years, 10 months ago) by dsouza
Changes since 1.18: +8 -1 lines
Diff to previous 1.18
Modified start_form method to let hidden input variables have multiple
values for the same variable name.
Thu Dec 6 16:11:51 2007 UTC (12 years ago) by parrello
Changes since 1.17: +2 -0 lines
Diff to previous 1.17
Added tracing support.
Mon Dec 3 16:04:20 2007 UTC (12 years ago) by paarmann
Diff to previous 1.16
fixed debug msg
Fri Nov 16 20:44:35 2007 UTC (12 years ago) by paczian
Changes since 1.15: +7 -2 lines
start_form method now has the additional optional paramter target to indicate the form action target
Mon Nov 5 18:36:08 2007 UTC (12 years, 1 month ago) by paczian
Changes since 1.14: +0 -82 lines
removed get_fig and get_genome_right methods
Fri Oct 26 20:05:38 2007 UTC (12 years, 1 month ago) by paczian
Changes since 1.13: +32 -9 lines
new and exciting features
Mon Oct 8 19:35:24 2007 UTC (12 years, 2 months ago) by paczian
Changes since 1.12: +63 -0 lines
added get_fig method
Wed Aug 29 15:59:52 2007 UTC (12 years, 3 months ago) by paczian
Changes since 1.11: +4 -4 lines
all hidden fields in start_form will have an id set to their name
Fri Aug 10 16:03:58 2007 UTC (12 years, 3 months ago) by paarmann
Changes since 1.10: +3 -0 lines
fixed start_form not reloading same page
Mon Jul 30 16:23:22 2007 UTC (12 years, 4 months ago) by paarmann
Changes since 1.9: +2 -1 lines
Mon Jul 30 14:04:53 2007 UTC (12 years, 4 months ago) by paarmann
Changes since 1.8: +56 -29 lines
added data method, minor fixes
Thu Jun 28 15:58:27 2007 UTC (12 years, 5 months ago) by paczian
Changes since 1.7: +9 -2 lines
fixed name function to work with backup pages
Wed Jun 27 21:04:58 2007 UTC (12 years, 5 months ago) by paczian
Changes since 1.6: +29 -6 lines
added supported_rights function
Tue Jun 19 21:30:40 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.5: +3 -2 lines
Added tracing.
Thu Jun 14 14:56:46 2007 UTC (12 years, 5 months ago) by paarmann
Changes since 1.4: +5 -11 lines
Thu May 17 15:21:58 2007 UTC (12 years, 6 months ago) by paczian
updated the name function to reflect changes in pakage names
Thu May 10 16:06:32 2007 UTC (12 years, 6 months ago) by paczian
Changes since 1.2: +10 -2 lines
modified start_form to allow overwriting of the page parameter
Fri Apr 27 16:02:14 2007 UTC (12 years, 7 months ago) by paczian
Changes since 1.1: +123 -7 lines
Thu Jan 11 16:45:32 2007 UTC (12 years, 10 months ago) by paarmann
Branch point for: fig
