[Bio] / WebApplication / WebMenu.pm Repository:
Log of /WebApplication/WebMenu.pm
Thu Mar 27 17:05:12 2008 UTC (11 years, 10 months ago) by paarmann
Diff to previous 1.10 , to selected 1.5
menu items without a link will now be properly formatted
Fri Jan 25 20:34:42 2008 UTC (12 years ago) by paarmann
Changes since 1.9: +17 -5 lines
Diff to previous 1.9 , to selected 1.5
added rights to menu entry
Wed Jan 16 22:17:51 2008 UTC (12 years, 1 month ago) by paarmann
Diff to previous 1.8 , to selected 1.5
Thu Dec 6 16:11:19 2007 UTC (12 years, 2 months ago) by parrello
Diff to previous 1.7 , to selected 1.5
Added tracing support.
Thu Nov 15 21:53:40 2007 UTC (12 years, 3 months ago) by paczian
Changes since 1.6: +8 -4 lines
menu entries no longer require a link
Mon Jul 30 20:47:31 2007 UTC (12 years, 6 months ago) by paarmann
Changes since 1.5: +11 -27 lines
Wed Jun 27 21:04:32 2007 UTC (12 years, 7 months ago) by paczian
Changes since 1.4: +29 -3 lines
added a space for a search component
Thu Jun 14 16:34:57 2007 UTC (12 years, 8 months ago) by paczian
Changes since 1.3: +10 -5 lines
added an order option to add_category
Fri Apr 27 16:02:14 2007 UTC (12 years, 9 months ago) by paczian
Changes since 1.2: +31 -9 lines
Wed Mar 14 20:19:03 2007 UTC (12 years, 11 months ago) by paarmann
Changes since 1.1: +23 -10 lines
Thu Jan 11 16:45:32 2007 UTC (13 years, 1 month ago) by paarmann
Branch point for: fig
Diff to selected 1.5
