[Bio] / WebApplication / WebMenu.pm Repository:
Log of /WebApplication/WebMenu.pm
Revision 1.13 - (view) (download) (as text) (annotate) - [selected]
Mon Oct 12 18:58:32 2009 UTC (10 years, 4 months ago) by jared
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.12: +2 -2 lines
Thu Jun 11 13:06:09 2009 UTC (10 years, 8 months ago) by paczian
Changes since 1.11: +119 -1 lines
Diff to previous 1.11 , to selected 1.13
added horizontal menu style
Thu Mar 27 17:05:12 2008 UTC (11 years, 10 months ago) by paarmann
Diff to previous 1.10 , to selected 1.13
menu items without a link will now be properly formatted
Fri Jan 25 20:34:42 2008 UTC (12 years ago) by paarmann
Changes since 1.9: +17 -5 lines
Diff to previous 1.9 , to selected 1.13
added rights to menu entry
Wed Jan 16 22:17:51 2008 UTC (12 years, 1 month ago) by paarmann
Diff to previous 1.8 , to selected 1.13
Thu Dec 6 16:11:19 2007 UTC (12 years, 2 months ago) by parrello
Diff to previous 1.7 , to selected 1.13
Added tracing support.
Thu Nov 15 21:53:40 2007 UTC (12 years, 3 months ago) by paczian
Changes since 1.6: +8 -4 lines
Diff to previous 1.6 , to selected 1.13
menu entries no longer require a link
Mon Jul 30 20:47:31 2007 UTC (12 years, 6 months ago) by paarmann
Changes since 1.5: +11 -27 lines
Diff to previous 1.5 , to selected 1.13
Wed Jun 27 21:04:32 2007 UTC (12 years, 7 months ago) by paczian
Changes since 1.4: +29 -3 lines
Diff to previous 1.4 , to selected 1.13
added a space for a search component
Thu Jun 14 16:34:57 2007 UTC (12 years, 8 months ago) by paczian
Changes since 1.3: +10 -5 lines
Diff to previous 1.3 , to selected 1.13
added an order option to add_category
Fri Apr 27 16:02:14 2007 UTC (12 years, 9 months ago) by paczian
Changes since 1.2: +31 -9 lines
Diff to previous 1.2 , to selected 1.13
Wed Mar 14 20:19:03 2007 UTC (12 years, 11 months ago) by paarmann
Changes since 1.1: +23 -10 lines
Diff to previous 1.1 , to selected 1.13
Thu Jan 11 16:45:32 2007 UTC (13 years, 1 month ago) by paarmann
Branch point for: fig
Diff to selected 1.13
