[Bio] / WebApplication / WebLayout.pm Repository:
Log of /WebApplication/WebLayout.pm
Mon Oct 12 13:34:19 2009 UTC (10 years, 9 months ago) by paczian
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.10: +35 -6 lines
allowing for multiple layouts
Wed Sep 3 21:01:14 2008 UTC (11 years, 10 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Changes since 1.9: +113 -11 lines
Converted URLs.
Fri Aug 1 16:52:35 2008 UTC (11 years, 11 months ago) by paczian
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_08_07
Changes since 1.8: +5 -0 lines
added method add_css_reverse
Tue Apr 29 21:12:04 2008 UTC (12 years, 2 months ago) by parrello
CVS Tags: rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.7: +1 -2 lines
Added tracing support.
Fri Apr 18 16:42:17 2008 UTC (12 years, 2 months ago) by paczian
CVS Tags: rast_rel_2008_04_23
Changes since 1.6: +8 -0 lines
added webcrawler / robot functions
Thu Mar 13 20:09:07 2008 UTC (12 years, 4 months ago) by paczian
switched priorities for css loading so custom will win over default
Thu Dec 6 16:10:30 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.4: +5 -0 lines
Added a quick shorthand method for setting variables.
Mon Aug 6 14:02:14 2007 UTC (12 years, 11 months ago) by paarmann
added user to template
Fri Apr 27 16:02:14 2007 UTC (13 years, 2 months ago) by paczian
Changes since 1.2: +47 -7 lines
Wed Mar 14 20:20:02 2007 UTC (13 years, 4 months ago) by paarmann
Thu Jan 11 16:45:32 2007 UTC (13 years, 6 months ago) by paarmann
Branch point for: fig
