[Bio] / WebApplication / WebLayout.pm Repository:
Log of /WebApplication/WebLayout.pm
Tue Jul 29 16:50:38 2014 UTC (5 years, 3 months ago) by olson
Changes since 1.14: +5 -0 lines
Use a template for setting app version.
Thu May 5 19:27:05 2011 UTC (8 years, 6 months ago) by olson
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, rast_rel_2011_0928
Changes since 1.13: +5 -0 lines
Add FIG_Config override for template variables
Wed Apr 6 11:12:31 2011 UTC (8 years, 7 months ago) by paczian
CVS Tags: mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0_4
Changes since 1.12: +23 -1 lines
added favicon support
Tue Nov 2 22:19:05 2010 UTC (9 years ago) by jared
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.11: +7 -6 lines
Mon Oct 12 13:34:19 2009 UTC (10 years, 1 month ago) by paczian
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.10: +35 -6 lines
allowing for multiple layouts
Wed Sep 3 21:01:14 2008 UTC (11 years, 2 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Changes since 1.9: +113 -11 lines
Converted URLs.
Fri Aug 1 16:52:35 2008 UTC (11 years, 3 months ago) by paczian
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_08_07
Changes since 1.8: +5 -0 lines
added method add_css_reverse
Tue Apr 29 21:12:04 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.7: +1 -2 lines
Added tracing support.
Fri Apr 18 16:42:17 2008 UTC (11 years, 7 months ago) by paczian
CVS Tags: rast_rel_2008_04_23
Changes since 1.6: +8 -0 lines
added webcrawler / robot functions
Thu Mar 13 20:09:07 2008 UTC (11 years, 8 months ago) by paczian
switched priorities for css loading so custom will win over default
Thu Dec 6 16:10:30 2007 UTC (11 years, 11 months ago) by parrello
Changes since 1.4: +5 -0 lines
Added a quick shorthand method for setting variables.
Mon Aug 6 14:02:14 2007 UTC (12 years, 3 months ago) by paarmann
added user to template
Fri Apr 27 16:02:14 2007 UTC (12 years, 6 months ago) by paczian
Changes since 1.2: +47 -7 lines
Wed Mar 14 20:20:02 2007 UTC (12 years, 8 months ago) by paarmann
Thu Jan 11 16:45:32 2007 UTC (12 years, 10 months ago) by paarmann
Branch: fig
CVS Tags: v_0_9
Diff to previous 1.1 , to next main 1.15
initial upload
Branch point for: fig
