[Bio] / WebApplication / WebConfig.pm Repository:
Log of /WebApplication/WebConfig.pm
Sun Jan 6 23:05:20 2013 UTC (7 years, 4 months ago) by golsen
Diff to previous 1.20
Get $NODB from FIG_Config.pm
our $NODB   = $FIG_Config::noWebAppDB;
Tue Sep 29 13:48:57 2009 UTC (10 years, 8 months ago) by paczian
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.19: +4 -4 lines
Diff to previous 1.19
login dependencies are now all vs all
Mon Jun 8 08:57:44 2009 UTC (10 years, 11 months ago) by paczian
Changes since 1.18: +2 -1 lines
Diff to previous 1.18
added login dependencies for PRAST
Thu Feb 5 07:32:06 2009 UTC (11 years, 4 months ago) by parrello
Diff to previous 1.17
Added NODB variable.
Wed Oct 22 17:46:21 2008 UTC (11 years, 7 months ago) by paczian
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05
Changes since 1.16: +3 -2 lines
Diff to previous 1.16
added login dependancies for MGRAST
Thu Oct 16 22:30:43 2008 UTC (11 years, 7 months ago) by olson
CVS Tags: rast_rel_2008_10_29
Changes since 1.15: +3 -2 lines
Initial changes to support mod_perl with RAST/SeedViewer:
Template loading requires absolute path. We use TMPL_PATH for this.
add_css used to use TMPL_PATH, but css paths are in URL space, not in
filesystem space. Add new TMPL_URL_PATH to WebConfig and use that instead.
WebApplication::run should not exit; mod_perl doesn't like it and it isn't necessary. Just return.
Fri Oct 10 12:29:30 2008 UTC (11 years, 7 months ago) by paczian
Changes since 1.14: +2 -1 lines
added login dependancy SeedViewer -> RAST
Wed Sep 10 14:07:32 2008 UTC (11 years, 8 months ago) by wilke
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
changed default admin email address
Thu Sep 4 19:06:25 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.12: +8 -5 lines
Tweaked the documentation to prevent future problems of this sort.
Thu Sep 4 18:59:57 2008 UTC (11 years, 9 months ago) by parrello
Fixed template path. Unlike the other path variables, the template path is a file location, not a web location.
Wed Sep 3 21:01:13 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.10: +5 -5 lines
Converted URLs.
Thu May 8 14:39:41 2008 UTC (12 years ago) by parrello
Changed some traces to warnings so they show on the feed.
Tue Apr 29 21:11:14 2008 UTC (12 years, 1 month ago) by parrello
Changes since 1.8: +8 -4 lines
Added tracing.
Wed Feb 20 16:51:53 2008 UTC (12 years, 3 months ago) by paarmann
CVS Tags: rast_rel_2008_04_23
Changes since 1.7: +22 -0 lines
Mon Nov 26 17:23:37 2007 UTC (12 years, 6 months ago) by paczian
Changes since 1.6: +9 -2 lines
added db config variables
Tue Oct 30 19:09:15 2007 UTC (12 years, 7 months ago) by paarmann
Fri Oct 26 16:28:23 2007 UTC (12 years, 7 months ago) by paarmann
added default tmp path
Tue Aug 14 21:52:40 2007 UTC (12 years, 9 months ago) by bartels
Changes since 1.3: +3 -3 lines
repaired file so that it works now, also for you...
CVS
Tue Aug 14 21:15:44 2007 UTC (12 years, 9 months ago) by paarmann
Changes since 1.2: +5 -2 lines
moved local config to FIGdisk/config
Tue Aug 14 18:55:36 2007 UTC (12 years, 9 months ago) by paarmann
Changes since 1.1: +19 -0 lines
added local config support
Fri Apr 27 16:02:14 2007 UTC (13 years, 1 month ago) by paczian
