[Bio] / WebApplication / WebComponent / OrganismSelect.pm Repository:
Log of /WebApplication/WebComponent/OrganismSelect.pm
Sun Aug 19 22:28:01 2012 UTC (7 years, 5 months ago) by golsen
Changes since 1.15: +6 -1 lines
Convert some undefined values to ''.
Tue Mar 29 14:07:36 2011 UTC (8 years, 10 months ago) by olson
CVS Tags: mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, rast_rel_2011_0928
Changes since 1.14: +0 -1 lines
Allow one to select both complete and incomplete genomes in the genome selector.
Wed Jun 3 13:07:13 2009 UTC (10 years, 7 months ago) by paczian
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, myrast_33, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.13: +23 -2 lines
all private organisms the user has access to will be shown again
Mon Apr 20 14:57:42 2009 UTC (10 years, 9 months ago) by paczian
CVS Tags: rast_rel_2009_05_18
Changes since 1.12: +2 -27 lines
now using new genome info method and adding all available private organisms to the figm
Wed Sep 3 21:01:19 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Changes since 1.11: +130 -117 lines
Converted URLs.
Thu Jul 24 14:45:42 2008 UTC (11 years, 6 months ago) by paczian
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_08_07
Changes since 1.10: +18 -0 lines
now includes a statistics attribute with the count of archaea, bacteria and so on
Thu May 8 14:41:29 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.9: +0 -1 lines
Removed a useless call that was breaking Sprout.
Wed May 7 23:14:04 2008 UTC (11 years, 8 months ago) by parrello
Fixed to work with Sprout.
Wed Apr 2 20:47:26 2008 UTC (11 years, 9 months ago) by paczian
CVS Tags: rast_rel_2008_04_23
Changes since 1.7: +11 -30 lines
now only displaying rast jobs if they are ready for viewing
Tue Mar 25 16:15:12 2008 UTC (11 years, 10 months ago) by paczian
Changes since 1.6: +2 -2 lines
added $self->id to name of component so you can use more than one of these at a time
Tue Mar 4 21:47:08 2008 UTC (11 years, 10 months ago) by paczian
Changes since 1.5: +27 -25 lines
checked if rast is present to prevent warning
Tue Mar 4 21:06:34 2008 UTC (11 years, 10 months ago) by paczian
Changes since 1.4: +12 -1 lines
added name function
Tue Mar 4 20:57:43 2008 UTC (11 years, 10 months ago) by paczian
updated some defaults
Tue Mar 4 20:45:35 2008 UTC (11 years, 10 months ago) by paczian
Changes since 1.2: +7 -1 lines
added maindomain letter to labels
Tue Mar 4 20:30:14 2008 UTC (11 years, 10 months ago) by paczian
Changes since 1.1: +22 -8 lines
added blacklist option
Tue Mar 4 19:46:28 2008 UTC (11 years, 10 months ago) by paczian
FilterSelect customized for organisms
