[Bio] / WebApplication / WebComponent / ModelMap.pm Repository:
Log of /WebApplication/WebComponent/ModelMap.pm
Wed Feb 1 06:34:38 2012 UTC (7 years, 11 months ago) by chenry
CVS Tags: HEAD, mgrast_version_3_2, mobedac_release_05302012, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.17: +207 -205 lines
Diff to previous 1.17
Changes to web components to fix bugs on Model SEED homepage and link to new Model SEED code
Fri May 20 07:32:23 2011 UTC (8 years, 8 months ago) by chenry
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, rast_rel_2011_0928
Changes since 1.16: +28 -28 lines
Diff to previous 1.16
Changes based on eliminating GetDBTable function.
Mon Feb 21 22:05:14 2011 UTC (8 years, 10 months ago) by chenry
CVS Tags: mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4
Changes since 1.15: +60 -85 lines
Changes fixing these components after small changes to Model SEED.
Sun Jan 2 22:00:23 2011 UTC (9 years ago) by chenry
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, myrast_33, rast_rel_2011_0119
Changes since 1.14: +13 -10 lines
Checking in accumulated changes to ModelSEED web components
Wed Aug 25 20:44:38 2010 UTC (9 years, 4 months ago) by chenry
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.13: +23 -29 lines
Fixing bug in visualization of compounds in kegg maps.
Mon Jul 26 15:09:13 2010 UTC (9 years, 5 months ago) by dejongh
Changes since 1.12: +14 -14 lines
Use relative path
Fri May 28 18:23:58 2010 UTC (9 years, 7 months ago) by dejongh
Fix getting map coordinates
Thu May 27 21:47:04 2010 UTC (9 years, 7 months ago) by dejongh
Changes since 1.10: +6 -7 lines
Changes to fix coloring of KEGG maps when there are multiple highlights for the same map object
Sun May 16 22:06:09 2010 UTC (9 years, 8 months ago) by chenry
Changes since 1.9: +4 -3 lines
Correction to handle change to Model PPO.
Thu Apr 15 21:54:31 2010 UTC (9 years, 9 months ago) by dejongh
CVS Tags: rast_rel_2010_0526
Changes since 1.8: +17 -3 lines
Highlight borders when reactions are active or essential; for reactions that are associated with pegs, match reaction with EC from functional role
Mon Apr 12 17:20:24 2010 UTC (9 years, 9 months ago) by chenry
Not sure why this is different...
Tue Mar 23 16:24:53 2010 UTC (9 years, 9 months ago) by devoid
Changes since 1.6: +65 -78 lines
Created AjaxKeggMap component. Refactored ModelMap to follow AjaxKeggMap structure / inheritance.
Mon Mar 22 16:05:48 2010 UTC (9 years, 10 months ago) by chenry
Changes since 1.5: +0 -4 lines
Mon Dec 21 19:59:26 2009 UTC (10 years ago) by chenry
CVS Tags: rast_rel_2010_0118
Changes since 1.4: +79 -83 lines
Fri Aug 21 20:28:38 2009 UTC (10 years, 5 months ago) by blinsay
CVS Tags: rast_rel_2009_0925
Changes since 1.3: +7 -7 lines
Thu Aug 20 21:01:47 2009 UTC (10 years, 5 months ago) by blinsay
Changes since 1.2: +494 -112 lines
Thu Jul 23 21:08:56 2009 UTC (10 years, 5 months ago) by blinsay
Changes since 1.1: +39 -21 lines
Added more robust error checking and a visible error dialogue above the map.
Thu Jul 16 16:14:44 2009 UTC (10 years, 6 months ago) by blinsay
Added model map component.
