[Bio] / WebApplication / WebComponent / DisplayListSelect.pm Repository:
Log of /WebApplication/WebComponent/DisplayListSelect.pm
Thu Jun 30 19:56:14 2011 UTC (8 years, 6 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.10: +1 -0 lines
Changed to new annotation security model.
Thu Jun 30 19:42:03 2011 UTC (8 years, 6 months ago) by parrello
Thu May 28 13:58:23 2009 UTC (10 years, 7 months ago) by arodri7
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
check for the correct rights in the headers
Thu Feb 5 18:45:59 2009 UTC (10 years, 11 months ago) by arodri7
Changes since 1.7: +10 -3 lines
updated display list select box bug
Fri Sep 12 16:53:47 2008 UTC (11 years, 4 months ago) by arodri7
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_release_2008_09_29
Changes since 1.6: +29 -10 lines
fixed id for filter_select
Wed Sep 3 21:01:19 2008 UTC (11 years, 4 months ago) by parrello
Converted URLs.
Fri Aug 15 18:12:30 2008 UTC (11 years, 5 months ago) by arodri7
CVS Tags: mgrast_rel_2008_0806
Changes since 1.4: +85 -31 lines
added filter select option to the DisplayList
Thu Jul 17 21:06:56 2008 UTC (11 years, 6 months ago) by arodri7
CVS Tags: rast_rel_2008_08_07
Changes since 1.3: +75 -35 lines
updates to the component
Tue Jul 15 20:01:04 2008 UTC (11 years, 6 months ago) by paczian
Changes since 1.2: +2 -5 lines
fixed rights checking for annotation column
Wed Jun 4 16:29:52 2008 UTC (11 years, 7 months ago) by arodri7
CVS Tags: rast_rel_2008_07_21
Changes since 1.1: +16 -1 lines
updated java script
Fri May 30 16:02:27 2008 UTC (11 years, 7 months ago) by arodri7
web component for having two list boxes that allows user to add or delete column from tables or other components
