[Bio] / WebApplication / WebComponent / Ajax.pm Repository:
Log of /WebApplication/WebComponent/Ajax.pm
Tue Jan 4 21:26:00 2011 UTC (9 years ago) by chenry
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.19: +1 -69 lines
Diff to previous 1.19
Bug fixes that will hopefully restore functionality of ModelView in Safari
Sun Jan 2 22:00:23 2011 UTC (9 years ago) by chenry
Changes since 1.18: +69 -1 lines
Diff to previous 1.18
Checking in accumulated changes to ModelSEED web components
Mon Aug 2 12:14:47 2010 UTC (9 years, 5 months ago) by paczian
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.17: +12 -1 lines
Diff to previous 1.17
added singleton mode for components
Wed Apr 21 19:22:15 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.16: +1 -0 lines
Diff to previous 1.16
Allow silent logins.
Thu Jul 2 12:48:53 2009 UTC (10 years, 6 months ago) by paczian
CVS Tags: rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118
Changes since 1.15: +8 -1 lines
allowing for ajax function calls to reside within a component
Thu May 28 18:10:45 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.14: +20 -28 lines
Added the ability to set cookies in an ajax response.
Fri Mar 13 19:04:34 2009 UTC (10 years, 10 months ago) by olson
Set  $FIG_Config::force_ajax_to_cgi_url to true if you wish to force
ajax to obey $FIG_Config::cgi_url.
Fri Mar 6 12:35:06 2009 UTC (10 years, 10 months ago) by paczian
Changes since 1.12: +1 -0 lines
fixed anonymous login bug
Thu Feb 5 07:32:50 2009 UTC (10 years, 11 months ago) by parrello
Added more tracing.
Thu Oct 9 17:13:05 2008 UTC (11 years, 3 months ago) by parrello
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05
Changes since 1.10: +9 -4 lines
Fixed to use an absolute URL in NMPDR mode.
Wed Oct 8 07:52:09 2008 UTC (11 years, 3 months ago) by paczian
Changes since 1.9: +2 -1 lines
fixed regexp
Tue Sep 30 14:24:55 2008 UTC (11 years, 3 months ago) by paczian
Changes since 1.8: +1 -0 lines
parsing port out of the url
Wed Sep 24 14:44:44 2008 UTC (11 years, 3 months ago) by paczian
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_release_2008_09_29
Changes since 1.7: +3 -1 lines
no longer needs FIG_Config variable to work
Wed Sep 3 21:01:19 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923
Changes since 1.6: +6 -12 lines
Converted URLs.
Mon Jun 9 15:20:18 2008 UTC (11 years, 7 months ago) by paczian
Changes since 1.5: +3 -0 lines
will now add a trailing slash to cgi_url if missing.
Mon Jun 9 15:14:53 2008 UTC (11 years, 7 months ago) by paczian
Changes since 1.4: +4 -0 lines
added a fig_config variable for the url of the script to support proxys
Fri Feb 15 20:27:23 2008 UTC (11 years, 11 months ago) by paczian
Changes since 1.3: +4 -1 lines
fixed regexp
Wed Dec 5 21:29:01 2007 UTC (12 years, 1 month ago) by paczian
Changes since 1.2: +1 -8 lines
removed loading from config, since WebApplication already does it...
Wed Dec 5 21:14:04 2007 UTC (12 years, 1 month ago) by paczian
Changes since 1.1: +7 -1 lines
dbmaster creation now uses WebConfig variables
Tue Jul 10 19:45:31 2007 UTC (12 years, 6 months ago) by paczian
initial version
