[Bio] / WebApplication / WebComponent.pm Repository:
Log of /WebApplication/WebComponent.pm
Links to mgrast_dev_06072011: (view) (download) (as text) (annotate)
Fri Feb 18 18:30:19 2011 UTC (9 years, 3 months ago) by devoid
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.7: +60 -5 lines
Implementing changes to WebApp for require_javascript_ordered() and require_css_ordered() calls.
Wed Sep 29 16:21:51 2010 UTC (9 years, 8 months ago) by paczian
CVS Tags: myrast_33, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.6: +10 -3 lines
added id manipulation for dynamic component creation
Mon Aug 2 12:14:47 2010 UTC (9 years, 10 months ago) by paczian
added singleton mode for components
Thu Feb 5 07:30:55 2009 UTC (11 years, 4 months ago) by parrello
CVS Tags: rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.4: +43 -1 lines
Added a utility method to construct javascript calls.
Thu Sep 4 18:59:15 2008 UTC (11 years, 9 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_release_2008_09_29
Fixed to allow SEED-mode testing on NMPDR machines.
Wed Sep 3 21:01:13 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.2: +15 -2 lines
Converted URLs.
Thu Jul 19 15:30:37 2007 UTC (12 years, 10 months ago) by paarmann
Changes since 1.1: +2 -4 lines
Fri Apr 27 16:02:14 2007 UTC (13 years, 1 month ago) by paczian
