[Bio] / WebApplication / WebApplicationDBHandle.pm Repository:
Log of /WebApplication/WebApplicationDBHandle.pm
Tue Apr 7 17:47:16 2009 UTC (11 years, 3 months ago) by paczian
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.1: +20 -0 lines
added WebServices authentication
Fri Jan 23 14:45:54 2009 UTC (11 years, 5 months ago) by paczian
initial version
module to return a dbmaster for the user database
