[Bio] / WebApplication / WebApplicationDBHandle.pm Repository:
Log of /WebApplication/WebApplicationDBHandle.pm
Links to mgrast_dev_04052011: (view) (download) (as text) (annotate)
Fri Feb 5 17:00:31 2010 UTC (10 years, 5 months ago) by paczian
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
fixed a possible exploit with 0 length key
Wed Dec 16 19:34:45 2009 UTC (10 years, 6 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Fixed syntax error in DBMaster constructor.
Mon Dec 7 09:21:43 2009 UTC (10 years, 7 months ago) by paczian
added optional socket
Tue Apr 7 17:47:16 2009 UTC (11 years, 3 months ago) by paczian
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.1: +20 -0 lines
added WebServices authentication
Fri Jan 23 14:45:54 2009 UTC (11 years, 5 months ago) by paczian
initial version
module to return a dbmaster for the user database
