[Bio] / WebApplication / SimpleWebPage.pm Repository:
Log of /WebApplication/SimpleWebPage.pm
Tue Nov 29 21:15:42 2011 UTC (8 years, 7 months ago) by disz
CVS Tags: mgrast_dev_12152011, mgrast_release_3_1_2
Added Use for devel stacktrace
Tue Nov 15 18:04:03 2011 UTC (8 years, 7 months ago) by olson
Changes since 1.2: +20 -2 lines
Add stacktrace support to SimpleWebPage.
if $FIG_Config::developer_mode is set, a failed page load of a web application will display the failure.
Mon Nov 14 19:47:46 2011 UTC (8 years, 7 months ago) by olson
Changes since 1.1: +4 -2 lines
Fix case where user not logged in
Thu Sep 1 17:58:30 2011 UTC (8 years, 10 months ago) by olson
CVS Tags: mgrast_dev_10262011, rast_rel_2011_0928
Simple seedviewer webpage wrapper.
