[Bio] / SubsystemExtension / subsystem_extension.pl Repository:
Log of /SubsystemExtension/subsystem_extension.pl
Fri Mar 3 18:15:56 2006 UTC (12 years, 10 months ago) by heiko
CVS Tags: HEAD
Changes since 1.2: +10 -14 lines
will always create variant prediction now
Sat Feb 4 14:15:59 2006 UTC (12 years, 11 months ago) by heiko
added the tempdir as default
Thu Jan 5 19:41:53 2006 UTC (13 years ago) by olson
Rearrangement for easier installation.
