[Bio] / SubsystemExtension / ValidationInterface.pm Repository:
Log of /SubsystemExtension/ValidationInterface.pm
Sat Feb 4 14:09:20 2006 UTC (13 years, 2 months ago) by heiko
CVS Tags: HEAD
Changes since 1.1: +8 -2 lines
variant output added
Fri Dec 30 08:41:53 2005 UTC (13 years, 3 months ago) by heiko
Branch: BRF
CVS Tags: release_0_1
Diff to previous 1.1 , to next main 1.2
Initial import
Branch point for: BRF
