[Bio] / SubsystemExtension / SubsystemVariant.pm Repository:
Log of /SubsystemExtension/SubsystemVariant.pm
Sat Feb 4 14:05:15 2006 UTC (13 years, 10 months ago) by heiko
CVS Tags: HEAD
Changes since 1.1: +48 -26 lines
output added, better scoring model
Fri Dec 30 08:41:53 2005 UTC (13 years, 11 months ago) by heiko
Branch: BRF
CVS Tags: release_0_1
Diff to previous 1.1 , to next main 1.2
Initial import
Branch point for: BRF
