[Bio] / SubsystemExtension / SubsystemCandidateFactory / GENDB.pm Repository:
Log of /SubsystemExtension/SubsystemCandidateFactory/GENDB.pm
Sat Feb 4 13:52:01 2006 UTC (14 years ago) by heiko
CVS Tags: HEAD
Changes since 1.1: +0 -3 lines
update: variant analysis removed
Fri Dec 30 08:41:53 2005 UTC (14 years, 1 month ago) by heiko
Branch: BRF
CVS Tags: release_0_1
Diff to previous 1.1 , to next main 1.2
Initial import
Branch point for: BRF
