[Bio] / SubsystemEditor / WebPage / ShowVariants.pm Repository:
Log of /SubsystemEditor/WebPage/ShowVariants.pm
Sat Jan 29 22:28:01 2011 UTC (8 years, 10 months ago) by redwards
CVS Tags: HEAD, myrast_33
Changes since 1.12: +3 -2 lines
merging diagram and illustration menus
Mon May 11 14:12:46 2009 UTC (10 years, 6 months ago) by bartels
Changes since 1.11: +68 -59 lines
bugfix ( prime is now working )
Mon Dec 22 17:01:20 2008 UTC (10 years, 11 months ago) by paczian
fixed bug when in no db mode
Mon Jul 7 18:50:53 2008 UTC (11 years, 5 months ago) by bartels
Changes since 1.9: +3 -10 lines
removed little bug
Fri May 23 21:45:02 2008 UTC (11 years, 6 months ago) by bartels
Changes since 1.8: +42 -5 lines
put in 100x100 stuff
Wed May 7 19:19:18 2008 UTC (11 years, 7 months ago) by bartels
Changes since 1.7: +70 -17 lines
changed the look-and-feel of the tables a bit
Mon May 5 20:06:46 2008 UTC (11 years, 7 months ago) by bartels
Changes since 1.6: +11 -8 lines
uri-escape...
Mon Mar 24 20:17:14 2008 UTC (11 years, 8 months ago) by bartels
Changes since 1.5: +57 -27 lines
fixed a bug - quotemeta rules.
Thu Mar 20 19:28:02 2008 UTC (11 years, 8 months ago) by bartels
Changes since 1.4: +104 -7 lines
Wed Mar 12 16:11:50 2008 UTC (11 years, 8 months ago) by bartels
Changes since 1.3: +5 -4 lines
Thu Sep 6 16:49:16 2007 UTC (12 years, 3 months ago) by bartels
Changes since 1.2: +5 -4 lines
bugfix
Fri Aug 31 20:43:46 2007 UTC (12 years, 3 months ago) by bartels
added some documentation
Fri Aug 31 20:39:34 2007 UTC (12 years, 3 months ago) by bartels
first version
