[Bio] / SubsystemEditor / WebPage / ShowSubsystem.pm Repository:
Log of /SubsystemEditor/WebPage/ShowSubsystem.pm
Sat Jan 29 22:28:01 2011 UTC (8 years, 11 months ago) by redwards
CVS Tags: HEAD, myrast_33
Changes since 1.34: +4 -2 lines
Diff to previous 1.34
merging diagram and illustration menus
Fri Jan 21 20:27:25 2011 UTC (9 years ago) by redwards
Changes since 1.33: +7 -4 lines
Diff to previous 1.33
Allowing users to add more than one word to describe a web page
Wed Sep 1 15:16:17 2010 UTC (9 years, 4 months ago) by paczian
Changes since 1.32: +24 -12 lines
Diff to previous 1.32
fixed rights display for ss shared to groups
Wed Sep 1 12:01:38 2010 UTC (9 years, 4 months ago) by paczian
Changes since 1.31: +1 -1 lines
Diff to previous 1.31
fixed rights revoking
Wed Nov 11 14:03:53 2009 UTC (10 years, 2 months ago) by paczian
Changes since 1.30: +2 -2 lines
Diff to previous 1.30
fixed incorrect regular expression in split for user name
Fri Oct 23 12:32:31 2009 UTC (10 years, 3 months ago) by paczian
Changes since 1.29: +2 -2 lines
Diff to previous 1.29
fixed reference error
Mon Oct 12 09:50:26 2009 UTC (10 years, 3 months ago) by paczian
Changes since 1.28: +38 -15 lines
Diff to previous 1.28
enabled sharing of ss to groups
Wed Jun 17 15:14:19 2009 UTC (10 years, 7 months ago) by paczian
Diff to previous 1.27
added test for anonymous mode
Tue May 12 13:31:39 2009 UTC (10 years, 8 months ago) by bartels
Changes since 1.26: +9 -40 lines
Diff to previous 1.26
Wed Apr 8 15:39:04 2009 UTC (10 years, 9 months ago) by paczian
Changes since 1.25: +40 -7 lines
Diff to previous 1.25
added groups to sharing mechanism
Thu Mar 19 12:03:24 2009 UTC (10 years, 10 months ago) by bartels
Changes since 1.24: +88 -1 lines
Diff to previous 1.24
Annotators can now grant / revoke rights for their subsystems.
Thu Mar 12 17:09:27 2009 UTC (10 years, 10 months ago) by bartels
Changes since 1.23: +7 -2 lines
Diff to previous 1.23
you can now see classifications that have a missing second classification
Mon Dec 29 15:19:12 2008 UTC (11 years ago) by bartels
Changes since 1.22: +2 -1 lines
Diff to previous 1.22
changed syntax for literature
Mon Dec 22 16:42:14 2008 UTC (11 years, 1 month ago) by paczian
Changes since 1.21: +2 -2 lines
Diff to previous 1.21
fixed bug when in no db mode
Tue Oct 7 09:37:32 2008 UTC (11 years, 3 months ago) by bartels
Changes since 1.20: +1 -0 lines
Diff to previous 1.20
added menu entry for subsetws
Thu Aug 14 20:04:20 2008 UTC (11 years, 5 months ago) by bartels
Changes since 1.19: +6 -3 lines
Diff to previous 1.19
changed link from old protein page to seedviewer and made button red
Tue Jul 29 18:41:20 2008 UTC (11 years, 5 months ago) by bartels
Changes since 1.18: +2 -2 lines
Diff to previous 1.18
changed the size of the description and the notes fields
Tue May 6 18:41:34 2008 UTC (11 years, 8 months ago) by bartels
Changes since 1.17: +0 -2 lines
Diff to previous 1.17
Tue May 6 18:30:26 2008 UTC (11 years, 8 months ago) by bartels
Changes since 1.16: +8 -8 lines
Diff to previous 1.16
Mon May 5 20:31:27 2008 UTC (11 years, 8 months ago) by bartels
Mon May 5 15:11:51 2008 UTC (11 years, 8 months ago) by bartels
Changes since 1.14: +27 -15 lines
escape ssname
Mon Apr 7 21:02:18 2008 UTC (11 years, 9 months ago) by bartels
changed just a menu entry
Fri Mar 21 15:54:30 2008 UTC (11 years, 10 months ago) by bartels
Changes since 1.12: +53 -0 lines
Thu Mar 20 19:26:57 2008 UTC (11 years, 10 months ago) by bartels
Changes since 1.11: +26 -0 lines
Thu Mar 13 20:19:04 2008 UTC (11 years, 10 months ago) by bartels
Changes since 1.10: +2 -1 lines
Thu Mar 13 19:36:58 2008 UTC (11 years, 10 months ago) by bartels
Changes since 1.9: +57 -0 lines
added capability for storing subsystem literature
Wed Mar 12 16:14:39 2008 UTC (11 years, 10 months ago) by bartels
Fri Feb 29 17:50:02 2008 UTC (11 years, 10 months ago) by bartels
Changes since 1.7: +1 -3 lines
had a nasty bug in the classification
Sat Feb 23 04:02:45 2008 UTC (11 years, 11 months ago) by bartels
Changes since 1.6: +3 -1 lines
user comparison is now case insensitive
Fri Feb 15 16:58:13 2008 UTC (11 years, 11 months ago) by bartels
Changes since 1.5: +24 -3 lines
if a user does not still have the right to edit his ss, but his seeduser and
the curator name of the subsystem are the same, he is now automatically granted
the right to edit the subsystem.
This is to solve the problem that the subsystem is created in the old interface,
so that the ppo user does not know about it
CVS
Thu Jan 17 21:43:41 2008 UTC (12 years ago) by bartels
Changes since 1.4: +1 -3 lines
Thu Dec 13 21:17:21 2007 UTC (12 years, 1 month ago) by bartels
Changes since 1.3: +17 -3 lines
removed nasty bug...
Thu Dec 13 17:46:23 2007 UTC (12 years, 1 month ago) by bartels
Changes since 1.2: +10 -1 lines
Mon Nov 19 15:51:39 2007 UTC (12 years, 2 months ago) by bartels
Changes since 1.1: +239 -14 lines
Tue Jul 31 21:54:24 2007 UTC (12 years, 5 months ago) by bartels
