[Bio] / SubsystemEditor / WebPage / ShowIllustrations.pm Repository:
Log of /SubsystemEditor/WebPage/ShowIllustrations.pm
Mon Jan 31 19:08:11 2011 UTC (8 years, 11 months ago) by redwards
CVS Tags: HEAD, myrast_33
Changes since 1.7: +3 -1 lines
correcting illustrations
Sat Jan 29 22:28:01 2011 UTC (8 years, 11 months ago) by redwards
merging diagram and illustration menus
Tue Oct 7 09:36:20 2008 UTC (11 years, 3 months ago) by bartels
added menu entry for subsets
Mon May 5 19:34:28 2008 UTC (11 years, 8 months ago) by bartels
Changes since 1.4: +16 -12 lines
escape...
Mon Apr 7 21:03:50 2008 UTC (11 years, 9 months ago) by bartels
changed just the menu
Thu Apr 3 20:49:06 2008 UTC (11 years, 9 months ago) by bartels
Changes since 1.2: +58 -9 lines
added delete option
Wed Mar 26 20:56:47 2008 UTC (11 years, 9 months ago) by bartels
Wed Mar 12 16:11:09 2008 UTC (11 years, 10 months ago) by bartels
