[Bio] / SubsystemEditor / WebPage / MetaSpreadsheet.pm Repository:
Log of /SubsystemEditor/WebPage/MetaSpreadsheet.pm
Fri Mar 20 18:37:10 2015 UTC (4 years, 10 months ago) by olson
CVS Tags: HEAD
Changes since 1.12: +22 -7 lines
Diff to previous 1.12 , to selected 1.2
Force zero variants to '-' in the PlusMinus view.
Mon Dec 22 17:01:20 2008 UTC (11 years, 1 month ago) by paczian
CVS Tags: myrast_33
Diff to previous 1.11 , to selected 1.2
fixed bug when in no db mode
Thu Oct 9 13:18:57 2008 UTC (11 years, 3 months ago) by bartels
Diff to previous 1.10 , to selected 1.2
bugfix
Fri Sep 26 12:32:56 2008 UTC (11 years, 3 months ago) by bartels
Changes since 1.9: +25 -3 lines
added buttons for variant codes
Tue Sep 16 15:08:24 2008 UTC (11 years, 4 months ago) by bartels
Changes since 1.8: +6 -6 lines
Mon Sep 15 10:27:51 2008 UTC (11 years, 4 months ago) by bartels
Changes since 1.7: +221 -30 lines
added add genome to metaspreadsheet
Thu Sep 11 12:00:05 2008 UTC (11 years, 4 months ago) by bartels
bugfix
Mon Sep 8 11:36:30 2008 UTC (11 years, 4 months ago) by bartels
Changes since 1.5: +6 -3 lines
Mon Sep 8 11:24:27 2008 UTC (11 years, 4 months ago) by bartels
Fri Sep 5 15:00:35 2008 UTC (11 years, 4 months ago) by bartels
Changes since 1.3: +111 -45 lines
added right assignment
Mon Aug 4 18:07:32 2008 UTC (11 years, 5 months ago) by bartels
Changes since 1.2: +9 -6 lines
Thu Jul 31 14:24:24 2008 UTC (11 years, 5 months ago) by bartels
Changes since 1.1: +206 -87 lines
Tue Jul 1 14:42:49 2008 UTC (11 years, 6 months ago) by bartels
Diff to selected 1.2
looking at a meta spreadsheet
