[Bio] / SubsystemEditor / WebPage / CopySubsystem.pm Repository:
Log of /SubsystemEditor/WebPage/CopySubsystem.pm
Mon Jun 20 16:57:25 2011 UTC (8 years, 7 months ago) by olson
CVS Tags: HEAD
Changes since 1.5: +53 -39 lines
Tighten up indexing of new subsystems.
Tue Jun 14 15:58:33 2011 UTC (8 years, 7 months ago) by olson
Set curator for newly copied subsystem.
Mon Sep 7 10:57:31 2009 UTC (10 years, 4 months ago) by bartels
CVS Tags: myrast_33
Changes since 1.3: +4 -2 lines
solved an error (hopefully :)
Mon Dec 22 17:01:20 2008 UTC (11 years, 1 month ago) by paczian
fixed bug when in no db mode
Wed Aug 6 16:16:31 2008 UTC (11 years, 5 months ago) by bartels
Tue Aug 5 15:41:09 2008 UTC (11 years, 5 months ago) by bartels
