[Bio] / SubsystemEditor / WebPage / CheckVariants.pm Repository:
Log of /SubsystemEditor/WebPage/CheckVariants.pm
Tue Sep 10 16:37:22 2013 UTC (6 years, 4 months ago) by overbeek
CVS Tags: HEAD
Changes since 1.12: +1 -0 lines
fix undef variable warning
Fri Aug 2 20:10:22 2013 UTC (6 years, 5 months ago) by overbeek
fix variant stuff
Fri Aug 2 20:04:31 2013 UTC (6 years, 5 months ago) by overbeek
-1 partial fix
Fri Aug 2 18:14:20 2013 UTC (6 years, 5 months ago) by overbeek
Changes since 1.9: +74 -144 lines
fix variant stuff
Sat Jan 29 22:28:01 2011 UTC (8 years, 11 months ago) by redwards
CVS Tags: myrast_33
Changes since 1.8: +3 -2 lines
merging diagram and illustration menus
Tue Jul 7 09:05:32 2009 UTC (10 years, 6 months ago) by bartels
Changes since 1.7: +1 -0 lines
added a button at the top for Gary
Tue Jun 2 13:22:48 2009 UTC (10 years, 7 months ago) by bartels
Changes since 1.6: +10 -4 lines
removed a small bug
Mon Dec 22 17:01:20 2008 UTC (11 years, 1 month ago) by paczian
fixed bug when in no db mode
Tue Oct 21 15:35:20 2008 UTC (11 years, 3 months ago) by bartels
another fix
Tue Oct 21 15:20:25 2008 UTC (11 years, 3 months ago) by bartels
Changes since 1.3: +38 -25 lines
bugfix
Thu Sep 25 15:35:24 2008 UTC (11 years, 4 months ago) by bartels
Changes since 1.2: +139 -105 lines
rules and definitions are now saved.
Mon May 5 20:04:06 2008 UTC (11 years, 8 months ago) by bartels
Changes since 1.1: +9 -7 lines
added uri-escape...
Thu Mar 20 19:26:14 2008 UTC (11 years, 10 months ago) by bartels
