[Bio] / SubsystemEditor / WebPage / ChangeCuratorSubsystem.pm Repository:
Log of /SubsystemEditor/WebPage/ChangeCuratorSubsystem.pm
Wed Jun 16 21:57:36 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: HEAD, myrast_33
Changes since 1.3: +0 -1 lines
Changes to support new figfams interface.
Mon Dec 22 17:01:20 2008 UTC (11 years, 1 month ago) by paczian
fixed bug when in no db mode
Sat Oct 25 09:48:10 2008 UTC (11 years, 2 months ago) by bartels
bugfix
Fri Oct 24 15:24:15 2008 UTC (11 years, 2 months ago) by bartels
changing the owner of a subsystem
