[Bio] / SubsystemEditor / SubsystemEditorLayout.tmpl Repository:
Log of /SubsystemEditor/SubsystemEditorLayout.tmpl
Thu May 5 21:25:26 2011 UTC (8 years, 7 months ago) by olson
CVS Tags: HEAD
Changes since 1.5: +5 -0 lines
Add find box.
Mon Jul 28 14:38:13 2008 UTC (11 years, 4 months ago) by paczian
CVS Tags: myrast_33
Changes since 1.4: +14 -6 lines
update menu bar
Thu Mar 27 20:18:06 2008 UTC (11 years, 8 months ago) by bartels
fixed a bug
Revision 1.3 - (view) (download) (annotate) - [selected]
Mon Nov 19 17:21:58 2007 UTC (12 years ago) by bartels
Changes since 1.2: +8 -2 lines
Wed May 23 02:32:21 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.1: +3 -4 lines
Fixed layout problems.
Mon May 14 21:05:57 2007 UTC (12 years, 6 months ago) by parrello
Diff to selected 1.3
Initial code for the new subsystem editor.
