[Bio] / SubsystemEditor / SubsysEditor.cgi Repository:
Log of /SubsystemEditor/SubsysEditor.cgi
Sun Jan 30 17:40:49 2011 UTC (8 years, 9 months ago) by redwards
CVS Tags: HEAD, myrast_33
Changes since 1.6: +1 -0 lines
fixing literature links for functional roles
Thu Jan 27 22:37:23 2011 UTC (8 years, 9 months ago) by olson
Changes since 1.5: +100 -16 lines
Speedups; begin support for fcgi server.
Tue Jan 15 17:05:27 2008 UTC (11 years, 10 months ago) by bartels
Changes since 1.4: +1 -2 lines
Fri Nov 30 19:42:36 2007 UTC (11 years, 11 months ago) by olson
Changes since 1.3: +0 -3 lines
Fixup
Mon Nov 19 15:44:14 2007 UTC (11 years, 11 months ago) by bartels
Changes since 1.2: +21 -31 lines
changed integration of login component
Mon Jul 16 20:07:16 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.1: +33 -19 lines
Initial implementation of subsystem editor, to be completed by Daniela.
Mon May 14 21:05:57 2007 UTC (12 years, 6 months ago) by parrello
Initial code for the new subsystem editor.
