[Bio] / SubsystemEditor / Makefile Repository:
Log of /SubsystemEditor/Makefile
Wed Jun 16 21:57:34 2010 UTC (9 years, 4 months ago) by olson
CVS Tags: HEAD, myrast_33
Changes to support new figfams interface.
Mon Dec 22 23:33:47 2008 UTC (10 years, 9 months ago) by olson
Changes since 1.6: +10 -1 lines
Add support for suexec - if CGI directory contains "public_html", ensure that any
installed CGI scripts and the CGI directory itself are not group or world writable.
Wed May 7 16:25:34 2008 UTC (11 years, 5 months ago) by paczian
removed -p from copy because it causes problems
Mon Mar 24 20:24:38 2008 UTC (11 years, 6 months ago) by paczian
Changes since 1.4: +0 -2 lines
removed rights thing
Fri Dec 21 23:05:34 2007 UTC (11 years, 9 months ago) by olson
Changes since 1.3: +4 -2 lines
use the seed perl
Mon Nov 19 15:43:45 2007 UTC (11 years, 11 months ago) by bartels
Changes since 1.2: +10 -7 lines
Thu Jul 26 19:40:36 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.1: +5 -5 lines
Mon May 14 21:05:57 2007 UTC (12 years, 5 months ago) by parrello
Initial code for the new subsystem editor.
