[Bio] / SubsystemEditor / Makefile Repository:
View of /SubsystemEditor/Makefile
Revision 1.8 - (download) (annotate)
Wed Jun 16 21:57:34 2010 UTC (9 years, 5 months ago) by olson
CVS Tags: myrast_33, HEAD
Changes to support new figfams interface.
# Public License.
# seed_running_perl.fragement is the piece of perl code that
# checks to see if the seed server is up, and prints a message and returns
# if it is not.
SEED_RUNNING_PERL = seed_running_perl.fragment
PERLCGISCRIPTS := $(subst .pl,,$(wildcard *.cgi))
PERL = $(shell sed -ne 's/^RTPERL=\(.*\)/\1/p' $(RTROOT)/config/RTConfig)
PERL_LIB = $(wildcard *.pm) \
	$(wildcard WebPage/*.pm)
WEBPAGES := $(wildcard *.tmpl) \
	$(wildcard images/*.png) \
	$(wildcard images/*.jpeg) \
        $(wildcard *.js) \
	$(wildcard *.css)
INST_PERL_LIB = $(foreach var, $(PERL_LIB), $(libdir)/$(PKGNAME)/$(var))
all: lib
show:
	@echo cgis $(foreach var, $(PERLCGISCRIPTS), $(cgidir)/$(var))
	@echo top $(TOPDIR)
	@echo pkg $(PKGNAME)
	@echo toolhdr $(TOOL_HDR)
bin:
lib:	$(foreach var, $(PERLCGISCRIPTS), $(cgidir)/$(var)) copy_htaccess $(INST_PERL_LIB) $(foreach var, $(WEBPAGES), $(cgidir)/Html/$(var)) rights fix_web_perms
fix_web_perms:
ifneq (,$(findstring public_html, $(cgidir)))
	chmod go-w $(cgidir)
endif
htaccess_src = $(RTROOT)/config/all.htaccess
htaccess_dst = $(cgidir)/.htaccess
copy_htaccess: force
	if test -f $(htaccess_src); then \
		 cp $(htaccess_src) $(htaccess_dst) ; \
	fi
force:
schematools:
stDeclFiles:
stGeneratedFiles:
test:
clean:
$(cgidir)/%: $(TOPDIR)/$(PKGNAME)/% $(TOOL_HDR)
	( cat $(TOOL_HDR) $< > $@; chmod +x $@ )
	chmod go-w $@
endif
$(cgidir)/Html/%: $(TOPDIR)/$(PKGNAME)/%
	cp $< $(cgidir)/Html/.
# We have a config problem at the moment.  I do not want to depend
# upon explicit calls to other packages, as done here nor do I want
# to assume that package was built first.  For now, we live with this.
#$(TOOL_HDR):
#	cd $(workdir); $(TOPDIR)/FigCommon/configure-env $(RTARCH) $(TOPDIR)
# Since our lib files have directories, need to create the target
# directory if it doesn't yet exist.
$(libdir)/$(PKGNAME)/%.pm: $(TOPDIR)/$(PKGNAME)/%.pm
	tgt_dir=`dirname $@`;  \
	if [ ! -d $$tgt_dir ] ; then \
		mkdir $$tgt_dir; \
	fi
	cp  $< $@
rights:
