[Bio] / StandaloneTools / run-glimmer.pl Repository:
Log of /StandaloneTools/run-glimmer.pl
Sat Dec 24 22:32:44 2005 UTC (13 years, 9 months ago) by overbeek
CVS Tags: HEAD
Changes since 1.1: +98 -72 lines
Added capability to train from an external set of calls and contigs. -- /gdp
Fri Sep 24 14:08:54 2004 UTC (15 years ago) by overbeek
Initial checkin
