Log of /Sprout/robots.txt
Links to mgrast_release_3_1_1: (view) (download) (annotate)
Tue Sep 16 18:50:33 2008 UTC (11 years, 5 months ago) by parrello
Changes since 1.3: +5 -8 lines
Removed some obsolete stuff.
Fri May 16 08:40:36 2008 UTC (11 years, 9 months ago) by parrello
Increased the crawl delay.
Mon May 5 19:27:08 2008 UTC (11 years, 9 months ago) by parrello
Added a 4-second crawl delay.
Mon Nov 5 21:29:45 2007 UTC (12 years, 3 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
