Log of /Sprout/robots.txt
Links to rast_rel_2009_03_26: (view) (download) (annotate)
Revision 1.4 - (view) (download) (annotate) - [selected]
Tue Sep 16 18:50:33 2008 UTC (11 years, 1 month ago) by parrello
Changes since 1.3: +5 -8 lines
Removed some obsolete stuff.
Fri May 16 08:40:36 2008 UTC (11 years, 5 months ago) by parrello
Increased the crawl delay.
Mon May 5 19:27:08 2008 UTC (11 years, 5 months ago) by parrello
Added a 4-second crawl delay.
Mon Nov 5 21:29:45 2007 UTC (11 years, 11 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Diff to selected 1.4
