Parent Directory
Revision Log
Target search support
#!/usr/bin/perl -w # # Copyright (c) 2003-2006 University of Chicago and Fellowship # for Interpretations of Genomes. All Rights Reserved. # # This file is part of the SEED Toolkit. # # The SEED Toolkit is free software. You can redistribute # it and/or modify it under the terms of the SEED Toolkit # Public License. # # You should have received a copy of the SEED Toolkit Public License # along with this program; if not write to the University of Chicago # at info@ci.uchicago.edu or the Fellowship for Interpretation of # Genomes at veronika@thefig.info or download a copy from # http://www.theseed.org/LICENSE.TXT. # package TargetCriterionCodeMatch; use strict; use Tracer; use Sprout; use base qw(TargetCriterionQuery); =head1 Code Match Target Search Criterion Object =head2 Introduction This is a search criterion object for search criteria involving a match against a single database field that has a code value. The user inputs the code value using the selection control, which is a configurable dropdown list. =head3 new my $tc = TargetCriterionCodeMatch->new($rhelp, $name, $label, $hint, \%codes, $field => @path); Construct a new TargetCriterionCodeMatch object. The following parameters are expected. =over 4 =item rhelp [[ResultHelperPm]] object for the active search. =item name Identifying name of this criterion. =item label Label to display for this criterion in the type dropdown. =item hint The hint tooltip to be displayed for this criterion. =item codes Hash of code values to the corresponding labels to be used in the selection dropdown. =item field Name of the database field containing the code value. =item path List of object names, indicating the path from the Feature or Genome table to the table containing the code value. The first object will be C<Feature> for a feature-based criterion and C<Genome> for a genome-based one. Frequently, the path will stop with the first object. When this happens, the criterion can be processed very efficiently. =back =cut sub new { # Get the parameters. my ($class, $rhelp, $name, $label, $hint, $codes, $field, @path) = @_; # Construct the underlying object. my $retVal = TargetCriterionQuery::new($class, $rhelp, { label => $label, hint => $hint, selectionData => $codes, name => $name}, $field, @path); # Return the object. return $retVal; } =head2 Virtual Methods =head3 Validate my $okFlag = $tc->Validate($parms); Return TRUE if the specified parameters are valid for a search criterion of this type and FALSE otherwise. If an error is detected, the error message can be retrieved using the L</message> method. =over 4 =item parms A Criterion Parameter Object whose fields are to be validated. =item RETURN Returns TRUE if the parameters are valid, else FALSE. =back =cut sub Validate { # Get the parameters. my ($self, $parms) = @_; # Default to valid. my $retVal = 1; # Get the selection value. my $value = $parms->{selection}; # Insure it matches one of the codes in the selection data. if (! exists $self->{selectionData}->{$value}) { # No, so we have an error. $self->SetMessage("Invalid selection \"$value\" for $self->{label}."); $retVal = 0; } # Return the validation code. return $retVal; } =head3 ComputeQuery my ($joins, $filterString, $parms) = $tc->ComputeQuery($criterion); Compute the SQL filter, join list, and parameter list for this criterion. If the criterion cannot be processed by SQL, then nothing is returned, and the criterion must be handled during post-processing. The join list and the parameter list should both be list references. The filter string is a true string. If the filter string only uses the B<Genome> and B<Feature> tables, then the join list can be left empty. Otherwise, the join list should start with the particular starting point (B<Genome> or B<Feature>) and list the path through the other relevant entities and relationships. Each criterion will have its own separate join path. =over 4 =item criterion Reference to a Criterion Parameter Object. =item RETURN Returns a 3-tuple consisting of the join list, the relevant filter string, and the matching parameters. If the criterion cannot be processed using SQL, then the return list contains three undefined values. (This is what happens if you don't override this method.) =back =cut sub ComputeQuery { # Get the parameters. my ($self, $criterion) = @_; # Get the name of the relevant field with the appropriate suffix. my $fieldName = $self->RelevantField($criterion->{idx}); # Compute the join list. my $joins = $self->JoinList(); # Compute the filter string. my $filterString = "$fieldName = ?"; # Finally, we build the parameter list, which contains the selection value. my $parms = [ $criterion->{selection} ]; # Return the results. return ($joins, $filterString, $parms); } =head3 CheckValue my $match = $tc->CheckValue($criterion, $valueData); Return TRUE if the current feature matches this criterion, else FALSE. =over 4 =item criterion Criterion Parameter object describing this criterion's parameters. =item valueData Value computed for the current feature by the L</GetValueData> method. =item RETURN Returns TRUE if the current feature matches the criterion, else FALSE. =back =cut sub CheckValue { # Get the parameters. my ($self, $criterion, $valueData) = @_; # Declare the return variable. my $value = $criterion->{selection}; # See if we can find a match. my $retVal = grep { $_ eq $value } @$valueData; # Return the result. return $retVal; } =head3 Sane my $flag = $tc->Sane($parms); Return TRUE if this is a sane criterion, else FALSE. Every search must have at least one sane criterion in order to be valid. =over 4 =item parms (optional) A Criterion Parameter Object for the current query. =item RETURN Returns TRUE if this query returns a relatively limited result set and uses SQL, else FALSE. If you do not override this method, it returns FALSE. =back =cut sub Sane { return 0; } 1;
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
