Parent Directory
Revision Log
ERDB 2.0 support
#!/usr/bin/perl -w # # Copyright (c) 2003-2006 University of Chicago and Fellowship # for Interpretations of Genomes. All Rights Reserved. # # This file is part of the SEED Toolkit. # # The SEED Toolkit is free software. You can redistribute # it and/or modify it under the terms of the SEED Toolkit # Public License. # # You should have received a copy of the SEED Toolkit Public License # along with this program; if not write to the University of Chicago # at info@ci.uchicago.edu or the Fellowship for Interpretation of # Genomes at veronika@thefig.info or download a copy from # http://www.theseed.org/LICENSE.TXT. # package SynonymSproutLoader; use strict; use Tracer; use ERDB; use base 'BaseSproutLoader'; =head1 Sprout Synonym Load Group Class =head2 Introduction The Synonym Load Group includes all of the major non-redundancy tables. =head3 new my $sl = SynonymSproutLoader->new($erdb, $options, @tables); Construct a new SynonymSproutLoader object. =over 4 =item erdb [[SproutPm]] object for the database being loaded. =item options Reference to a hash of command-line options. =item tables List of tables in this load group. =back =cut sub new { # Get the parameters. my ($class, $erdb, $options) = @_; # Create the table list. my @tables = sort qw(SynonymGroup IsSynonymGroupFor); # Create the BaseSproutLoader object. my $retVal = BaseSproutLoader::new($class, $erdb, $options, @tables); # Return it. return $retVal; } =head2 Public Methods =head3 Generate $sl->Generate(); Generate the data for the non-redundancy files. =cut sub Generate { # Get the parameters. my ($self) = @_; # Get the sprout object. my $sprout = $self->db(); # Get the FIG object. my $fig = $self->source(); # Is this the global section? if (! $self->global()) { # No, then get the section ID. my $genomeID = $self->section(); # Get the database handle. my $dbh = $fig->db_handle(); # Ask for the synonyms. Note that "maps_to" is a group name, and "syn_id" is a PEG ID or alias. my $sth = $dbh->prepare_command("SELECT maps_to, syn_id FROM peg_synonyms WHERE syn_id LIKE ?"); my $result = $sth->execute("fig|$genomeID%"); if (! defined($result)) { Confess("Database error in Synonym load: " . $sth->errstr()); } else { Trace("Processing synonym results for $genomeID.") if T(2); # Loop through the synonym/peg pairs. while (my @row = $sth->fetchrow()) { # Get the synonym group ID and feature ID. my ($syn_id, $peg) = @row; # Count this row. $self->Add('synonyms-read' => 1); # Insure it's not deleted. if ($fig->is_deleted_fid($peg)) { $self->Add('synonyms-skipped' => 1); } else { # Create the group record. $self->PutE(SynonymGroup => $syn_id); # Connect the synonym to the peg. $self->PutR(IsSynonymGroupFor => $syn_id, $peg); } } } } } 1;
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
