[Bio] / Sprout / SubsystemSaplingLoader.pm Repository:
Log of /Sprout/SubsystemSaplingLoader.pm
Wed May 8 20:28:44 2013 UTC (6 years, 8 months ago) by parrello
Diff to previous 1.20
Updates for new incremental load.
Sat Feb 26 19:05:32 2011 UTC (8 years, 10 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2011_0928
Diff to previous 1.19
Even more loader fixes.
Sun Feb 6 14:23:13 2011 UTC (8 years, 11 months ago) by parrello
Changes since 1.18: +63 -58 lines
Diff to previous 1.18
Fixed to handle subsystems being deleted while the load is running.
Mon Jan 24 03:52:18 2011 UTC (9 years ago) by parrello
Changes since 1.17: +2 -1 lines
Diff to previous 1.17
More loader fixes.
Wed Nov 24 18:49:01 2010 UTC (9 years, 2 months ago) by parrello
Diff to previous 1.16
Fixed handling of missing subsystem classes.
Wed Sep 29 18:00:40 2010 UTC (9 years, 3 months ago) by parrello
Changes since 1.15: +5 -1 lines
Wed Jul 7 19:23:41 2010 UTC (9 years, 6 months ago) by parrello
Changes since 1.14: +18 -2 lines
General loader improvements.
Wed Jun 9 20:04:54 2010 UTC (9 years, 7 months ago) by parrello
Changes since 1.13: +3 -0 lines
Changed to handle flaky subsystems without crashing.
Thu Mar 25 16:20:40 2010 UTC (9 years, 10 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Misc load fixes.
Mon Feb 1 20:14:28 2010 UTC (9 years, 11 months ago) by parrello
Changes since 1.11: +122 -121 lines
Sapling model updates.
Wed Dec 16 01:45:19 2009 UTC (10 years, 1 month ago) by parrello
CVS Tags: rast_rel_2010_0118
Changes since 1.10: +2 -0 lines
Sapling v08 changes.
Wed Nov 25 20:58:27 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.9: +4 -0 lines
Fixed to work properly for null descriptions.
Wed Jul 15 23:39:58 2009 UTC (10 years, 6 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.8: +40 -19 lines
Tue Jun 30 19:53:51 2009 UTC (10 years, 6 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Fixed error in subsystem Contains relationship.
Tue Jun 16 16:33:58 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.6: +14 -10 lines
Updated to use new subsystem key structure.
Thu Jun 4 18:21:46 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.5: +27 -6 lines
Added new data to subsystems.
Thu May 28 18:08:56 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.4: +28 -22 lines
Thu Apr 2 01:49:17 2009 UTC (10 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Fixed to clean subsystem objects.
Mon Mar 2 22:37:05 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.2: +64 -63 lines
Changed to allow for multiple molecular machines per genome.
Thu Feb 5 07:26:14 2009 UTC (10 years, 11 months ago) by parrello
Changes since 1.1: +8 -6 lines
Changed to respond better to errors in the corresponding ID table.
Mon Jan 19 21:43:05 2009 UTC (11 years ago) by parrello
CVS Tags: rast_rel_2009_02_05
Sapling support.
