[Bio] / Sprout / SproutSubsys.pm Repository:
Log of /Sprout/SproutSubsys.pm
Wed Jun 11 17:48:03 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.14: +85 -0 lines
Diff to previous 1.14 , to selected 1.5
Added stub for get_hope_reactions_for_genome.
Tue Apr 29 20:56:39 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.13: +50 -9 lines
Diff to previous 1.13 , to selected 1.5
Fixed some bad documentation, added get_roles_for_genome.
Sun Mar 23 16:34:17 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.12: +17 -2 lines
Diff to previous 1.12 , to selected 1.5
Implemented get_description.
Thu Dec 6 14:50:08 2007 UTC (12 years ago) by parrello
Changes since 1.11: +189 -24 lines
Diff to previous 1.11 , to selected 1.5
Changed POD format for better compatability with Wiki. Added support for "get_row", "get_hope_reaction", and "get_row_subset".
Mon Jul 16 19:59:33 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.10: +80 -3 lines
Diff to previous 1.10 , to selected 1.5
Tue Apr 10 06:16:22 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.9: +29 -0 lines
Diff to previous 1.9 , to selected 1.5
Added support for SEED Viewer methods.
Tue Oct 17 18:45:58 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.8: +148 -11 lines
Diff to previous 1.8 , to selected 1.5
Added diagram support.
Sun Jun 18 05:50:10 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.7: +2 -0 lines
Diff to previous 1.7 , to selected 1.5
Fixed a space.
Thu Jun 8 19:44:02 2006 UTC (13 years, 6 months ago) by parrello
Fixed to use the correct key when trying to access a spreadsheet cell.
Thu Dec 8 19:51:37 2005 UTC (14 years ago) by parrello
Changes since 1.5: +11 -6 lines
Fixed a bug in "get_diagrams".
Thu Dec 8 18:04:12 2005 UTC (14 years ago) by parrello
Fixed a bug in the get_variant_code method.
Mon Nov 28 22:52:11 2005 UTC (14 years ago) by parrello
Changes since 1.3: +62 -2 lines
Fixed some comments.
Added "get_diagrams".
Thu Oct 20 10:19:30 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.2: +3 -1 lines
Fixed reaction hash table to include only roles with reactions attached. Previously, such roles would map to an empty list.
Tue Oct 18 20:06:22 2005 UTC (14 years, 1 month ago) by parrello
Fixed error in initializing the reaction data.
Wed Oct 12 03:30:08 2005 UTC (14 years, 2 months ago) by parrello
Diff to selected 1.5
Added to provide limited Subsystem.pm functionality for Sprout.
