[Bio] / Sprout / SproutSubsys.pm Repository:
Log of /Sprout/SproutSubsys.pm
Thu Jun 4 18:21:58 2009 UTC (10 years, 7 months ago) by parrello
Diff to previous 1.22 , to selected 1.17
Fixed a comment.
Thu Apr 2 01:49:00 2009 UTC (10 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.21: +1 -1 lines
Diff to previous 1.21 , to selected 1.17
Fixed a bug in genome/role processing.
Mon Jan 19 21:44:01 2009 UTC (11 years ago) by parrello
Changes since 1.20: +296 -51 lines
Diff to previous 1.20 , to selected 1.17
Changed to support scenarios and to work faster.
Wed Oct 15 11:46:57 2008 UTC (11 years, 3 months ago) by parrello
Changes since 1.19: +1 -0 lines
Diff to previous 1.19 , to selected 1.17
Added a trace message.
Tue Sep 16 18:45:06 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
Changes since 1.18: +79 -54 lines
Diff to previous 1.18 , to selected 1.17
Upgraded to be able to handle scenarios.
Tue Sep 9 21:02:10 2008 UTC (11 years, 4 months ago) by parrello
Changes since 1.17: +97 -7 lines
Diff to previous 1.17
Changes for v24 database.
Revision 1.17 - (view) (download) (as text) (annotate) - [selected]
Tue Sep 9 00:27:25 2008 UTC (11 years, 4 months ago) by parrello
Diff to previous 1.16
Changed an Open so that if it fails, it shows up in the RSS feed.
Sun Sep 7 03:12:55 2008 UTC (11 years, 4 months ago) by parrello
Diff to previous 1.15 , to selected 1.17
Added HACK markers to the places that need changing in v24.
Wed Jun 11 17:48:03 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.14: +85 -0 lines
Diff to previous 1.14 , to selected 1.17
Added stub for get_hope_reactions_for_genome.
Tue Apr 29 20:56:39 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.13: +50 -9 lines
Diff to previous 1.13 , to selected 1.17
Fixed some bad documentation, added get_roles_for_genome.
Sun Mar 23 16:34:17 2008 UTC (11 years, 9 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.12: +17 -2 lines
Diff to previous 1.12 , to selected 1.17
Implemented get_description.
Thu Dec 6 14:50:08 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.11: +189 -24 lines
Diff to previous 1.11 , to selected 1.17
Changed POD format for better compatability with Wiki. Added support for "get_row", "get_hope_reaction", and "get_row_subset".
Mon Jul 16 19:59:33 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.10: +80 -3 lines
Diff to previous 1.10 , to selected 1.17
Tue Apr 10 06:16:22 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.9: +29 -0 lines
Diff to previous 1.9 , to selected 1.17
Added support for SEED Viewer methods.
Tue Oct 17 18:45:58 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.8: +148 -11 lines
Diff to previous 1.8 , to selected 1.17
Added diagram support.
Sun Jun 18 05:50:10 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.7: +2 -0 lines
Diff to previous 1.7 , to selected 1.17
Fixed a space.
Thu Jun 8 19:44:02 2006 UTC (13 years, 7 months ago) by parrello
Diff to previous 1.6 , to selected 1.17
Fixed to use the correct key when trying to access a spreadsheet cell.
Thu Dec 8 19:51:37 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.5: +11 -6 lines
Diff to previous 1.5 , to selected 1.17
Fixed a bug in "get_diagrams".
Thu Dec 8 18:04:12 2005 UTC (14 years, 1 month ago) by parrello
Diff to previous 1.4 , to selected 1.17
Fixed a bug in the get_variant_code method.
Mon Nov 28 22:52:11 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.3: +62 -2 lines
Diff to previous 1.3 , to selected 1.17
Fixed some comments.
Added "get_diagrams".
Thu Oct 20 10:19:30 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.2: +3 -1 lines
Diff to previous 1.2 , to selected 1.17
Fixed reaction hash table to include only roles with reactions attached. Previously, such roles would map to an empty list.
Tue Oct 18 20:06:22 2005 UTC (14 years, 3 months ago) by parrello
Diff to previous 1.1 , to selected 1.17
Fixed error in initializing the reaction data.
Wed Oct 12 03:30:08 2005 UTC (14 years, 3 months ago) by parrello
Diff to selected 1.17
Added to provide limited Subsystem.pm functionality for Sprout.
