[Bio] / Sprout / SproutSubsys.pm Repository:
View of /Sprout/SproutSubsys.pm
Revision 1.19 - (download) (as text) (annotate)
Tue Sep 16 18:45:06 2008 UTC (11 years, 5 months ago) by parrello
CVS Tags: rast_2008_0924, rast_rel_2008_09_30, mgrast_rel_2008_0924, mgrast_rel_2008_0625, rast_rel_2008_10_09, rast_release_2008_09_29, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2008_09_29, mgrast_rel_2008_0917
Changes since 1.18: +79 -54 lines
Upgraded to be able to handle scenarios.
#!/usr/bin/perl -w
package SproutSubsys;
    use strict;
    use Tracer;
    use PageBuilder;
    use FIG;
    use Sprout;
=head1 Sprout Subsystem Object
=head2 Introduction
This object emulates the capabilities of the FIG-style C<Subsystem> object, but
uses Sprout methods to retrieve the data. This object can be dropped in place of
the UnvSubsys object to create subsystem displays for the Sprout rather than the
SEED.
The structure created by the constructor contains the following data members.
=over 4
=item name
Name of the subsystem. This is needed for any further database accesses required.
=item curator
Name of the subsystem's official curator.
=item notes
General notes about the subsystem.
=item sprout
Sprout object for accessing the database. This is a genuine Sprout object, not
an SFXlate object.
=item genomeHash
Map of genome IDs to row indices.
=item genomes
List of [genomeID, variantCode] tuples in row order.
=item roleHash
Map of role IDs and abbreviations to column indices. In other words, plugging
either a full-blown role ID or its abbreviation into this hash will return
the role's column index.
=item roles
List of [roleID, abbreviation] tuples in column order.
=item dir
Directory root for the diagram and image files.
=item reactionHash
Map of role IDs to a list of the reactions catalyzed by the role.
=item colorHash
Map of PEG IDs to cluster numbers. This is used to create color maps for
display of a subsystem's PEGs.
=item hopeReactions
Map of roles to EC numbers for the Hope reactions. This object is not loaded
until it is needed.
=back
=cut
#: Constructor SproutSubsys->new();
=head2 Public Methods
=head3 new
    my $sub = SproutSubsys->new($subName, $sprout);
Load the subsystem.
=over 4
=item subName
Name of the desired subsystem.
=item sprout
Sprout or SFXlate object for accessing the Sprout data store.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $subName, $sprout) = @_;
    # Insure we have a Sprout object.
    if (ref $sprout eq 'SFXlate') {
        $sprout = $sprout->{sprout};
    # Declare the return value.
    my $retVal;
    # Get the subsystem's object.
    my $subsystemObject = $sprout->GetEntity('Subsystem', $subName);
    if (! defined $subsystemObject) {
        # Here we're stuck.
        Confess("Subsystem \"$subName\" not found in database.");
    } else {
        # We've found it, so get the major data.
        my ($curator, $notes, $description, $version) = $subsystemObject->Values(['Subsystem(curator)', 'Subsystem(notes)',
                                                            'Subsystem(description)', 'Subsystem(version)']);
        # Get the genome IDs and variant codes for the rows. The list returned
        # by GetAll will be a list of 2-tuples, each consisting of a genome ID
        # and a subsystem variant code.
        my @genomes = $sprout->GetAll(['ParticipatesIn'],
                                      'ParticipatesIn(to-link) = ? ORDER BY ParticipatesIn(variant-code), ParticipatesIn(from-link)',
                                      [$subName], ['ParticipatesIn(from-link)',
                                                   'ParticipatesIn(variant-code)']);
        # Create the genome ID directory. This is a hash that maps a genome ID to its
        # row index.
        my $idx = 0;
        my %genomeHash = map { $_->[0] => $idx++ } @genomes;
        # Get the role IDs and abbreviations. The list returned by GetAll will be
        # a list of 2-tuples, each consisting of a role ID and abbreviation. The
        # 2-tuples will be ordered by the spreadsheet column number.
        my @roles = $sprout->GetAll(['OccursInSubsystem'],
                                    'OccursInSubsystem(to-link) = ? ORDER BY OccursInSubsystem(column-number)',
                                    [$subName], ['OccursInSubsystem(from-link)', 'OccursInSubsystem(abbr)',
                                                 'OccursInSubsystem(auxiliary)']);
        # Now we need to create the role ID directory, which maps role IDs and their
        # abbreviations to column numbers.
        my %roleHash = ();
        my %abbrHash = ();
        my %auxHash = ();
        for ($idx = 0; $idx <= $#roles; $idx++) {
            # Get the role ID, aux flag, and abbreviation for this column's role.
            my ($roleID, $abbr, $aux) = @{$roles[$idx]};
            # Put the ID and abbreviation in the role directory.
            $roleHash{$roleID} = $idx;
            $roleHash{$abbr} = $idx;
            # Put the aux flag in the aux hash.
            $auxHash{$roleID} = $aux;
            # Put the full name in the abbreviation directory.
            $abbrHash{$abbr} = $roleID;
        # Find the subsystem directory.
        my $subDir = Subsystem::get_dir_from_name($subName);
        Trace("Subsystem directory is $subDir.") if T(3);
        # Create the subsystem object.
        $retVal = {
                    # Name of the subsystem. This is needed for any further database
                    # accesses required.
                    name => $subName,
                    # Directory root for diagram and image files.
                    dir => $subDir,
                    # Name of the subsystem's official curator.
                    curator => $curator,
                    # General notes about the subsystem.
                    notes => $notes,
                    # Sprout object for accessing the database.
                    sprout => $sprout,
                    # Map of genome IDs to row indices.
                    genomeHash => \%genomeHash,
                    # List of [genomeID, variantCode] tuples in row order.
                    genomes => \@genomes,
                    # Map of role IDs and abbreviations to column indices.
                    roleHash => \%roleHash,
                    # List of [roleID, abbreviation] tuples in column order.
                    roles => \@roles,
                    # Map of PEG IDs to cluster numbers.
                    colorHash => {},
                    # Map of abbreviations to role names.
                    abbrHash => \%abbrHash,
                    # Map of auxiliary rols.
                    auxHash => \%auxHash,
                    # Map of role IDs to reactions.
                    reactionHash => undef,
                    # Version number.
                    version => $version,
        # Bless and return it.
        bless $retVal, $class;
    return $retVal;
=head3 is_aux_role
    my $flag = $sub->is_aux_role($roleID);
Return TRUE if the specified role is auxiliary to this subsystem, FALSE
if it is essential to it.
=over 4
=item roleID
ID of the relevant role.
=item RETURN
Returns TRUE if the specified role is auxiliary, else FALSE.
=back
=cut
sub is_aux_role {
    my ($self, $roleID) = @_;
    my $retVal = $self->{auxHash}->{$roleID};
    # Return the result.
    return $retVal;
=head3 get_row
    my $rowData = $sub->get_row($rowIndex);
Return the specified row in the subsystem spreadsheet. The row consists
of a list of lists. Each position in the major list represents the role
for that position, and contains a list of the IDs for the features that
perform the role.
=over 4
=item rowIndex
Index of the row to return. A row contains data for a single genome.
=item RETURN
Returns a reference to a list of lists. Each element in the list represents
a spreadsheet column (role) and contains a list of features that perform the
role.
=back
=cut
sub get_row {
    my ($self, $rowIndex) = @_;
    # Get the genome ID for the specified row's genome.
    my $genomeID = $self->{genomes}->[$rowIndex]->[0];
    # Read the row from the database. We won't get exactly what we want. Instead, we'll
    # get a list of triplets, each consisting of a role name, a feature ID, and a cluster
    # number. We need to convert this into a list of lists and stash the clustering information
    # in the color hash.
    my @rowData = $self->{sprout}->GetAll([qw(Subsystem HasSSCell IsGenomeOf IsRoleOf ContainsFeature)],
                                          "Subsystem(id) = ? AND IsGenomeOf(from-link) = ?",
                                          [$self->{name}, $genomeID],
                                          [qw(IsRoleOf(from-link) ContainsFeature(to-link)
                                              ContainsFeature(cluster-number))]);
    # Now we do the conversion. We must first create an array of empty lists, one per
    # row index.
    my @retVal = map { [] } @{$self->{roles}};
    # Get the hash for converting role IDs to role indexes.
    my $roleHash = $self->{roleHash};
    # Now we stash all the feature IDs in the appropriate columns of the row list.
    for my $rowDatum (@rowData) {
        # Get the role ID, the peg ID, and the cluster number.
        my ($role, $peg, $cluster) = @{$rowDatum};
        # Put the peg in the role's peg list.
        push @{$retVal[$roleHash->{$role}]}, $peg;
        # Put the cluster number in the color hash.
        $self->{colorHash}->{$peg} = $cluster;
    return \@retVal;
=head3 get_roles_for_genome
    my @roles = $sub->get_roles_for_genome($genome_id);
Return a list of the roles in this subsystem that have nonempty
spreadsheet cells for the given genome.
=over 4
=item genome_id
ID of the relevant genome.
=item RETURN
Returns a list of role IDs.
=back
=cut
sub get_roles_for_genome {
    my ($self, $genome_id) = @_;
    # This next statement gets all of the nonempty cells for the genome's row and memorizes
    # the roles by rolling them into a hash. The query connects four relationship tables on
    # a single common key-- the spreadsheet cell ID. The IsGenomeOf table insures the cell is for the
    # correct genome. The HasSSCell table insures that it belongs to the correct subsystem. The
    # ContainsFeature table insures that it contains at least one feature. Finally, IsRoleOf tells
    # us the cell's role. If a cell has more than one feature, the result list from the query will return
    # one instance of the role for every distinct feature. The hash collapses the duplicates automatically.
    my %retVal = map { $_ => 1 } $self->{sprout}->GetFlat([qw(ContainsFeature HasSSCell IsGenomeOf IsRoleOf)],
                                                          "HasSSCell(from-link) = ? AND IsGenomeOf(from-link) = ?",
                                                          [$self->{name}, $genome_id], 'IsRoleOf(from-link)');
    return keys %retVal;
=head3 get_abbr_for_role
    my $abbr = $sub->get_abbr_for_role($name);
Get this subsystem's abbreviation for the specified role.
=over 4
=item name
Name of the relevant role.
=item RETURN
Returns the abbreviation for the role. Each subsystem has its own abbreviation
system; the abbreviations make it easier to display the subsystem spreadsheet.
=back
=cut
sub get_abbr_for_role {
    my ($self, $name) = @_;
    # Get the index for this role.
    my $idx = $self->get_role_index($name);
    # Return the abbreviation.
    return $self->get_role_abbr($idx);
=head3 get_subsetC
    my @columns = $sub->get_subsetC($subsetName);
Return a list of the column numbers for the columns in the named role
subset.
=over 4
=item subsetName
Name of the subset whose columns are desired.
=item RETURN
Returns a list of the indices for the columns in the named subset.
=back
=cut
sub get_subsetC {
    my ($self, $subsetName) = @_;
    # Get the roles in the subset.
    my @roles = $self->get_subsetC_roles($subsetName);
    # Convert them to indices.
    my @retVal = map { $roleHash->{$_} } @roles;
    return @retVal;
=head3 get_genomes
    my @genomeList = $sub->get_genomes();
Return a list of the genome IDs for this subsystem. Each genome corresponds to a row
in the subsystem spreadsheet. Indexing into this list returns the ID of the genome
in the specified row.
=cut
sub get_genomes {
    my ($self) = @_;
    # Return a list of the genome IDs. The "genomes" member contains a 2-tuple
    # with the genome ID followed by the variant code. We only return the
    # genome IDs.
    my @retVal = map { $_->[0] } @{$self->{genomes}};
    return @retVal;
=head3 get_variant_code
    my $code = $sub->get_variant_code($gidx);
Return the variant code for the specified genome. Each subsystem has multiple
variants which involve slightly different chemical reactions, and each variant
has an associated variant code. When a genome is connected to the spreadsheet,
the subsystem variant used by the genome must be specified.
=over 4
=item gidx
Row index for the genome whose variant code is desired.
=item RETURN
Returns the variant code for the specified genome.
=back
=cut
sub get_variant_code {
    my ($self, $gidx) = @_;
    # Extract the variant code for the specified row index. It is the second
    # element of the tuple from the "genomes" member.
    my $retVal = $self->{genomes}->[$gidx]->[1];
    return $retVal;
=head3 get_curator
    my $userName = $sub->get_curator();
Return the name of this subsystem's official curator.
=cut
sub get_curator {
    my ($self) = @_;
    # Return the curator member.
    return $self->{curator};
=head3 get_notes
    my $text = $sub->get_notes();
Return the descriptive notes for this subsystem.
=cut
sub get_notes {
    my ($self) = @_;
    # Return the notes member.
    return $self->{notes};
=head3 get_description
    my $text = $sub->get_description();
Return the description for this subsystem.
=cut
sub get_description
    my($self) = @_;
    return $self->{description};
=head3 get_roles
    my @roles = $sub->get_roles();
Return a list of the subsystem's roles. Each role corresponds to a column
in the subsystem spreadsheet. The list entry at a specified position in
the list will contain the ID of that column's role.
=cut
sub get_roles {
    my ($self) = @_;
    # Return the list of role IDs. The role IDs are stored as the first
    # element of each 2-tuple in the "roles" member.
    my @retVal = map { $_->[0] } @{$self->{roles}};
    return @retVal;
=head3 get_reactions
    my $reactHash = $sub->get_reactions();
Return a reference to a hash that maps each role ID to a list of the reactions
=cut
sub get_reactions {
    my ($self) = @_;
    # Do we already have a reaction hash?
    my $retVal = $self->{reactionHash};
    if (! $retVal) {
        # No, so we'll build it.
        $retVal = {};
        my $sprout = $self->{sprout};
        for my $roleID ($self->get_roles()) {
            # Get this role's reactions.
            my @reactions = $sprout->GetFlat(['Catalyzes'], 'Catalyzes(from-link) = ?',
                                             [$roleID], 'Catalyzes(to-link)');
            # Put them in the reaction hash.
            if (@reactions > 0) {
                $retVal->{$roleID} = \@reactions;
        # Save it for future use.
        $self->{reactionHash} = $retVal;
    # Return the reaction hash.
    return $retVal;
=head3 get_subset_namesC
    my @subsetNames = $sub->get_subset_namesC();
Return a list of the names for all the column (role) subsets. Given a subset
name, you can use the L</get_subsetC_roles> method to get the roles in the
subset.
=cut
sub get_subset_namesC {
    my ($self) = @_;
    # Get the sprout object and use it to retrieve the subset names.
    my @subsets = $sprout->GetFlat(['HasRoleSubset'], 'HasRoleSubset(from-link) = ?',
                                   [$self->{name}], 'HasRoleSubset(to-link)');
    # The sprout subset names are prefixed by the subsystem name. We need to pull the
    # prefix off before we return the results. The prefixing character is a colon (:),
    # so we search for the last colon to get ourselves the true subset name.
    my @retVal = map { $_ =~ /:([^:]+)$/; $1 } @subsets;
    return @retVal;
    my @subsetNames = $sub->get_subset_names();
Return the names of the column subsets.
=cut
sub get_subset_names{
    my ($self) = @_;
    return $self->get_subset_namesC();
=head3 get_role_abbr
    my $abbr = $sub->get_role_abbr($ridx);
Return the abbreviation for the role in the specified column. The abbreviation
is a shortened identifier that is not necessarily unique, but is more likely to
fit in a column heading.
=over 4
=item ridx
Column index for the role whose abbreviation is desired.
=item RETURN
Returns an abbreviated name for the role corresponding to the indexed column.
=back
=cut
sub get_role_abbr {
    my ($self, $ridx) = @_;
    # Return the role abbreviation. The abbreviation is the second element
    # in the 2-tuple for the specified column in the "roles" member.
    my $retVal = $self->{roles}->[$ridx]->[1];
    return $retVal;
=head3 get_hope_reactions_for_genome
    my %ss_reactions = $subsys->get_hope_reactions_for_genome($genome);
This method returns a hash that maps reactions to the pegs that catalyze
them for the specified genome. For each role in the subsystem, the pegs
are computed, and these are attached to the reactions for the role.
=over 4
=item genome
ID of the genome whose reactions are to be put into the hash.
=item RETURN
Returns a hash mapping reactions in the subsystem to pegs in the
specified genome, or an empty hash if the genome is not found in the
subsystem.
=back
=cut
sub get_hope_reactions_for_genome {
    my($self, $genome) = @_;
    my %retVal;
    # Look for the genome in our spreadsheet.
    my $index = $self->get_genome_index($genome);
    # Only proceed if we found it.
    if (defined $index) {
        # Extract the roles.
        my @roles = $self->get_roles;
        # Get the hope reaction hash. For each role, this gives us a list
        # of reactions.
        my %hope_reactions = $self->get_hope_reactions();
        # Loop through the cells in this genome's role.
        for my $role (@roles) {
            # Get the features in this role's cell.
            my @peg_list = $self->get_pegs_from_cell($genome,$role);
            # Only proceed if we have hope reactions AND pegs for this role.
            if (defined $hope_reactions{$role} && scalar @peg_list > 0) {
                # Loop through the reactions, pushing the pegs in this cell onto
                # the reaction's peg list.
                for my $reaction (@{$hope_reactions{$role}}) {
                    push @{$retVal{$reaction}}, @peg_list;
    return %retVal;
=head3 get_hope_additional_reactions
    my %ss_reactions = $subsys->get_hope_additional_reactions($scenario_name);
Return a list of the additional reactions for the specified scenario.
=over 4
=item scenario_name
Name of the scenario whose additional reactions are desired.
=item RETURN
Returns a list of the additional reactions attached to the named scenario.
=back
=cut
sub get_hope_additional_reactions {
    my($self, $scenario_name) = @_;
    # Ask the database for this scenario's additional reactions.
    my @retVal = $self->{sprout}->GetFlat(['IncludesReaction'], "IncludesReaction(from-link) = ?",
                                          [$scenario_name], 'IncludesReaction(to-link)');
    return @retVal;
    my %reactionHash = $subsys->get_hope_reactions();
Return a hash mapping the roles of this subsystem to the EC numbers for
the reactions used in scenarios (if any). It may return an empty hash
if the Hope reactions are not yet known.
=cut
sub get_hope_reactions {
    my ($self) = @_;
    # Try to get the hope reactions from the object.
    my $retVal = $self->{hopeReactions};
    if (! defined($retVal)) {
        # They do not exist, so we must create them. Make a copy of the role-to-reaction
        # hash.
        my %hopeHash = %{$self->get_reactions()};
        # Insure we have it if we need it again.
        $retVal = \%hopeHash;
        $self->{hopeReactions} = $retVal;
    return %{$retVal};
=head3 get_hope_reaction_notes
    my %roleHash = $sub->get_hope_reaction_notes();
Return a hash mapping the roles of the subsystem to any existing notes
about the relevant reactions.
=cut
sub get_hope_reaction_notes {
    my ($self) = @_;
    my %retVal;
    # Get the database object.
    # Get our name.
    my $ssName = $self->{name};
    # Loop through the roles, getting each role's hope notes.
    for my $role ($self->get_roles()) {
        my ($note) = $self->get_hop_reaction_note($role);
        # If this role had a nonempty note, stuff it in the hash.
        if ($note) {
            $retVal{$role} = $note;
    return %retVal;
    my $note = $sub->get_hope_reaction_note($role);
Return the text note about the curation of the scenario reactions
relating to this role.
=over 4
=item role
ID of the role whose note is desired.
=item RETURN
Returns the relevant role's note for this subsystem's hope reactions, or FALSE (empty string
or undefined) if no such note was found.
=back
=cut
sub get_hope_reaction_note {
    my ($self, $role) = @_;
    # Ask the database for the note.
    my ($retVal) = $self->{sprout}->GetFlat(['OccursInSubsystem'],
                                            "OccursInSubsystem(from-link) = ? AND OccursInSubsystem(to-link) = ?",
                                            [$role, $self->{name}], 'OccursInSubsystem(hope-reaction-note)');
    return $retVal;
=head3 get_role_index
    my $idx = $sub->get_role_index($role);
Return the column index for the role with the specified ID.
=over 4
=item role
ID (full name) or abbreviation of the role whose column index is desired.
=item RETURN
Returns the column index for the role with the specified name or abbreviation.
=back
=cut
sub get_role_index {
    # The role index is directly available from the "roleHash" member.
    my $retVal = $self->{roleHash}->{$role};
    return $retVal;
=head3 get_subsetC_roles
    my @roles = $sub->get_subsetC_roles($subname);
Return the names of the roles contained in the specified role (column) subset.
=over 4
=item subname
Name of the role subset whose roles are desired.
=item RETURN
Returns a list of the role names for the columns in the named subset.
=back
=cut
sub get_subsetC_roles {
    my ($self, $subname) = @_;
    # Get the sprout object. We need it to be able to get the subset data.
    # Convert the subset name to Sprout format. In Sprout, the subset name is
    # prefixed by the subsystem name in order to get a unique subset ID.
    my $subsetID = $self->{name} . ":$subname";
    # Get a list of the role names for this subset.
    my @roleNames = $sprout->GetFlat(['ConsistsOfRoles'], 'ConsistsOfRoles(from-link) = ?',
                                  [$subsetID], 'ConsistsOfRoles(to-link)');
    # Sort them by column number. We get the column number from the role hash.
    my @retVal = sort { $roleHash->{$a} <=> $roleHash->{$b} } @roleNames;
    # Return the sorted list.
    return @retVal;
=head3 get_genome_index
    my $idx = $sub->get_genome_index($genome);
Return the row index for the genome with the specified ID.
=over 4
=item genome
ID of the genome whose row index is desired.
=item RETURN
Returns the row index for the genome with the specified ID, or an undefined
value if the genome does not participate in the subsystem.
=back
=cut
sub get_genome_index {
    my ($self, $genome) = @_;
    # Get the genome row index from the "genomeHash" member.
    my $retVal = $self->{genomeHash}->{$genome};
    return $retVal;
=head3 get_cluster_number
    my $number = $sub->get_cluster_number($pegID);
Return the cluster number for the specified PEG, or C<-1> if the
cluster number for the PEG is unknown or it is not clustered.
The cluster number is read into the color hash by the
L</get_pegs_from_cell> method. If the incoming PEG IDs do not
come from the most recent cell retrievals, the information returned
will be invalid. This is a serious design flaw which needs to be
fixed soon.
=over 4
=item pegID
ID of the PEG whose cluster number is desired.
=item RETURN
Returns the appropriate cluster number.
=back
=cut
#: Return Type $;
sub get_cluster_number {
    my ($self, $pegID) = @_;
    my $retVal = -1;
    # Check for a cluster number in the color hash.
    if (exists $self->{colorHash}->{$pegID}) {
        $retVal = $self->{colorHash}->{$pegID};
    return $retVal;
=head3 get_pegs_from_cell
    my @pegs = $sub->get_pegs_from_cell($rowstr, $colstr);
Return a list of the peg IDs for the features in the specified spreadsheet cell.
=over 4
=item rowstr
Genome row, specified either as a row index or a genome ID.
=item colstr
Role column, specified either as a column index, a role name, or a role
abbreviation.
=item RETURN
Returns a list of PEG IDs. The PEGs in the list belong to the genome in the
specified row and perform the role in the specified column. If the indicated
row and column does not exist, returns an empty list.
=back
=cut
sub get_pegs_from_cell {
    my ($self, $rowstr, $colstr) = @_;
    # Get the sprout object for accessing the database.
    # We need to convert the incoming row and column identifiers. We need a
    # numeric column index and a character genome ID to create the ID for the
    # subsystem spreadsheet cell. First, the column index: note that our version
    # of "get_role_index" conveniently works for both abbreviations and full role IDs.
    my $colIdx = ($colstr =~ /^(\d+)$/ ? $colstr : $self->get_role_index($colstr));
    # Next the genome ID. In this case, we convert any number we find to a string.
    # This requires a little care to avoid a run-time error if the row number is
    # out of range.
    my $genomeID = $rowstr;
    if ($rowstr =~ /^(\d+)$/) {
        # Here we need to convert the row number to an ID. Insure the number is in
        # range. Note that if we do have a row number out of range, the genome ID
        # will be invalid, and our attempt to read from the database will return an
        # empty list.
        my $genomeList = $self->{genomes};
        if ($rowstr >= 0 && $rowstr < @{$genomeList}) {
            $genomeID = $genomeList->[$rowstr]->[0];
    # Construct the spreadsheet cell ID from the information we have.
    my $cellID = $sprout->DigestKey($self->{name} . ":$genomeID:$colIdx");
    # Get the list of PEG IDs and cluster numbers for the indicated cell.
    my @pegList = $sprout->GetAll(['ContainsFeature'], 'ContainsFeature(from-link) = ?',
                                  [$cellID], ['ContainsFeature(to-link)',
                                              'ContainsFeature(cluster-number)']);
    # Copy the pegs into the return list, and save the cluster numbers in the color hash.
    my @retVal = ();
    for my $pegEntry (@pegList) {
        my ($peg, $cluster) = @{$pegEntry};
        push @retVal, $peg;
    # Return the list. If the spreadsheet cell was empty or non-existent, we'll end
    # up returning an empty list.
    return @retVal;
=head3 get_subsetR
    my @genomes = $sub->get_subsetR($subName);
Return the genomes in the row subset indicated by the specified subset name.
=over 4
=item subName
Name of the desired row subset, or C<All> to get all of the rows.
=item RETURN
Returns a list of genome IDs corresponding to the named subset.
=back
=cut
sub get_subsetR {
    my ($self, $subName) = @_;
    # Look for the specified row subset in the database. A row subset is identified using
    # the subsystem name and the subset name. The special subset "All" is actually
    # represented in the database, so we don't need to check for it.
    my @rows = $self->{sprout}->GetFlat(['ConsistsOfGenomes'], "ConsistsOfGenomes(from-link) = ?",
                                        ["$self->{name}:$subName"], 'ConsistsOfGenomes(to-link)');
    return @rows;
=head3 get_diagrams
    my @list = $sub->get_diagrams();
Return a list of the diagrams associated with this subsystem. Each diagram
is represented in the return list as a 4-tuple C<[diagram_id, diagram_name,
page_link, img_link]> where
=over 4
=item diagram_id
ID code for this diagram.
=item diagram_name
Displayable name of the diagram.
=item page_link
URL of an HTML page containing information about the diagram.
=item img_link
URL of an HTML page containing an image for the diagram.
=back
Note that the URLs are in fact for CGI scripts with parameters that point them
to the correct place. Though Sprout has diagram information in it, it has
no relationship to the diagrams displayed in SEED, so the work is done entirely
on the SEED side.
=cut
sub get_diagrams {
    my ($self) = @_;
    # Get the diagram IDs.
    my @diagramIDs = Subsystem::GetDiagramIDs($self->{dir});
    Trace("Diagram IDs are " . join(", ", @diagramIDs)) if T(3);
    # Create the return variable.
    my @retVal = ();
    # Loop through the diagram IDs.
    for my $diagramID (@diagramIDs) {
        Trace("Processing diagram $diagramID.") if T(3);
        my ($name, $link, $imgLink) = $self->get_diagram($diagramID);
        Trace("Diagram $name URLs are \"$link\" and \"$imgLink\".") if T(3);
        push @retVal, [$diagramID, $name, $link, $imgLink];
    return @retVal;
=head3 get_diagram
    my ($name, $pageURL, $imgURL) = $sub->get_diagram($id);
Get the information (if any) for the specified diagram. The diagram corresponds
to a subdirectory of the subsystem's C<diagrams> directory. For example, if the
diagram ID is C<d03>, the diagram's subdirectory would be C<$dir/diagrams/d03>,
where I<$dir> is the subsystem directory. The diagram's name is extracted from
a tiny file containing the name, and then the links are computed using the
subsystem name and the diagram ID. The parameters are as follows.
=over 4
=item id
ID code for the desired diagram.
=item RETURN
Returns a three-element list. The first element is the diagram name, the second
a URL for displaying information about the diagram, and the third a URL for
displaying the diagram image.
=back
=cut
sub get_diagram {
    my($self, $id) = @_;
    my $name = Subsystem::GetDiagramName($self->{dir}, $id);
    my ($link, $img_link) = Subsystem::ComputeDiagramURLs($self, $self->{name}, $id, 1);
    return($name, $link, $img_link);
=head3 get_diagram_html_file
    my $fileName = $sub->get_diagram_html_file($id);
Get the HTML file (if any) for the specified diagram. The diagram corresponds
where I<$dir> is the subsystem directory. If an HTML file exists, it will be
named C<diagram.html> in the diagram directory.  The parameters are as follows.
=over 4
=item id
=item RETURN
Returns the name of an HTML diagram file, or C<undef> if no such file exists.
=back
=cut
sub get_diagram_html_file {
    my ($self, $id) = @_;
    my $retVal;
    my $ddir = "$self->{dir}/diagrams/$id";
    if (-d $ddir) {
        my $html = "$ddir/diagram.html";
        if (-f $html) {
            $retVal = $html;
    return $retVal;
=head3 is_new_diagram
    my $flag = $sub->is_new_diagram($id);
Return TRUE if the specified diagram is in the new format, else FALSE.
=over 4
=item id
ID code (e.g. C<d03>) of the relevant diagram.
=item RETURN
Returns TRUE if the diagram is in the new format, else FALSE.
=back
=cut
sub is_new_diagram {
  my $image_map = $self->get_diagram_html_file($id);
  if ($image_map) {
    Trace("Image map found for diagram $id at $image_map.") if T(3);
    Open(\*IN, "<$image_map");
    my $header = <IN>;
    close(IN);
    if ($header =~ /\<map name=\"GraffleExport\"\>/) {
      return 1;
  return undef;
=head3 get_role_from_abbr
    my $roleName = $sub->get_role_from_abbr($abbr);
Return the role name corresponding to an abbreviation.
=over 4
=item abbr
Abbreviation name of the relevant role.
=item RETURN
Returns the full name of the specified role.
=back
=cut
sub get_role_from_abbr {
    my($self, $abbr) = @_;
    # Get the role name from the abbreviation hash.
    my $retVal = $self->{abbrHash}->{$abbr};
    # Check for a case incompatability.
    if (! defined $retVal) {
        $retVal = $self->{abbrHash}->{lcfirst $abbr};
    return $retVal;
=head3 get_name
    my $name = $sub->get_name();
Return the name of this subsystem.
=cut
sub get_name {
    my ($self) = @_;
    return $self->{name};
=head3 open_diagram_image
    my ($type, $fh) = $sub->open_diagram_image($id);
Open a diagram's image file and return the type and file handle.
=over 4
=item id
ID of the desired diagram
=item RETURN
Returns a 2-tuple containing the diagram's MIME type and an open filehandle
for the diagram's data. If the diagram does not exist, the type will be
returned as <undef>.
=back
=cut
sub open_diagram_image {
    # Declare the return variables.
    my ($type, $fh);
    # Get the diagram directory.
    my $img_base = "$self->{dir}/diagrams/$id/diagram";
    # Get a list of file extensions and types.
    my %types = (png => "image/png",
                 gif => "image/gif",
                 jpg => "image/jpeg");
    # This is my new syntax for the for-each-while loop.
    # We loop until we run out of keys or come up with a type value.
    for my $ext (keys %types) { last if (defined $type);
        my $myType = $types{$ext};
        # Compute a file name for this diagram.
        my $file = "$img_base.$ext";
        # If it exists, try to open it.
        if (-f $file) {
            $fh = Open(undef, "<$file");
            $type = $myType;
    return ($type, $fh);
1;
