[Bio] / Sprout / SproutLoad.pm Repository:
Log of /Sprout/SproutLoad.pm
Sun Mar 23 16:33:15 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.91: +15 -4 lines
Diff to previous 1.91 , to selected 1.84
Added code to pull the corresponding IDs into the feature keyword list.
Thu Feb 14 19:15:18 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.90: +0 -2 lines
Diff to previous 1.90 , to selected 1.84
Removed some obsolete comments.
Thu Dec 6 14:53:50 2007 UTC (12 years ago) by parrello
Changes since 1.89: +30 -21 lines
Diff to previous 1.89 , to selected 1.84
Changed POD format for better compatability with Wiki. Added more tracing. Fixed a bug in the load for the PDB-Feature relationship.
Mon Nov 5 23:43:57 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.88: +14 -7 lines
Diff to previous 1.88 , to selected 1.84
Fixed an error in the CDD parsing.
Mon Nov 5 22:52:06 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.87: +7 -1 lines
Diff to previous 1.87 , to selected 1.84
Fixed an error in the alias handler.
Mon Sep 10 18:16:54 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.86: +8 -4 lines
Diff to previous 1.86 , to selected 1.84
Fixed load of diagram information.
Mon Aug 20 23:30:35 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.85: +3 -3 lines
Diff to previous 1.85 , to selected 1.84
Removed subsystem classification from a feature's keyword list.
Mon Jul 16 19:59:33 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.84: +202 -263 lines
Diff to previous 1.84
Revision 1.84 - (view) (download) (as text) (annotate) - [selected]
Thu May 17 23:44:51 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.83: +15 -10 lines
Diff to previous 1.83
Fixed some bugs in the drug target load.
Fri May 11 06:37:38 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.82: +172 -229 lines
Diff to previous 1.82 , to selected 1.84
Added new tables for drug target docking results.
Tue Apr 10 06:15:35 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.81: +17 -7 lines
Diff to previous 1.81 , to selected 1.84
Added support for new fields required by the SEED Viewer.
Wed Feb 21 13:21:42 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.80: +6 -13 lines
Diff to previous 1.80 , to selected 1.84
Changed so that the functional assignment for non-PEG features is obtained from the annotations rather than the aliases.
Wed Dec 20 20:04:58 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.79: +64 -11 lines
Diff to previous 1.79 , to selected 1.84
Changed to get attributes in larger batches to improve performance.
Sat Nov 18 20:38:45 2006 UTC (13 years ago) by parrello
Changes since 1.78: +10 -4 lines
Diff to previous 1.78 , to selected 1.84
Added taxonomy to search words. Fixed bust-up algorithm to preserve word order in assignments.
Wed Nov 15 12:15:30 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.77: +1 -1 lines
Diff to previous 1.77 , to selected 1.84
Converted to use the configured splitter for subsystem classifications.
Thu Nov 9 21:23:43 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.76: +15 -12 lines
Diff to previous 1.76 , to selected 1.84
Fixed some bugs in the special attribute support.
Fri Nov 3 00:43:22 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.75: +351 -12 lines
Diff to previous 1.75 , to selected 1.84
Added code to load Drug Target data. Fixed the keyword search code.
Sun Oct 22 05:17:10 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.74: +45 -12 lines
Diff to previous 1.74 , to selected 1.84
Changed to use the first alias as the primary functional assignment of non-peg features.
Sat Oct 21 06:44:17 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.73: +1 -1 lines
Diff to previous 1.73 , to selected 1.84
Fixed the subsystem classification code to use colon instead of space as a delimiter between levels.
Fri Oct 20 20:42:56 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.72: +0 -72 lines
Diff to previous 1.72 , to selected 1.84
Removed obsolete BBH load.
Sat Oct 14 18:12:14 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.71: +49 -11 lines
Diff to previous 1.71 , to selected 1.84
Changed the subsystem classification implementation so that we can reconstruct the correct hierarchy.
Added new implementations for virulence and essentialiy properties.
Wed Sep 27 13:25:53 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.70: +1 -1 lines
Diff to previous 1.70 , to selected 1.84
Fixed a bad Put.
Wed Sep 27 12:58:18 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.69: +1 -1 lines
Diff to previous 1.69 , to selected 1.84
Put a better index on HasRoleInSubsystem.
Wed Sep 27 12:34:46 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.68: +10 -1 lines
Diff to previous 1.68 , to selected 1.84
Added a relationship between features and subsystems.
Sun Sep 24 17:14:16 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.67: +15 -17 lines
Diff to previous 1.67 , to selected 1.84
Moved NMPDR group into the Genome record. This insures that all of the information required to generate a popup menu of genomes is available without access to secondary tables.
Tue Sep 19 00:11:12 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.66: +3 -1 lines
Diff to previous 1.66 , to selected 1.84
Changed to include a copy of the functional assignment in the feature table.
Wed Sep 6 19:30:53 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.65: +2 -2 lines
Diff to previous 1.65 , to selected 1.84
Enhanced to sort genome IDs so that progress can be measured more accurately from the trace messages.
Sun Aug 27 00:05:45 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.64: +5 -1 lines
Diff to previous 1.64 , to selected 1.84
Fixed a bug in the handling of the gene file access code. How could this ever have worked?
Sat Aug 12 08:43:37 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.63: +6 -3 lines
Diff to previous 1.63 , to selected 1.84
Fixed to load subsystem classifications as a multiply-occurring field.
Wed Aug 2 23:51:19 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.62: +4 -4 lines
Diff to previous 1.62 , to selected 1.84
Fixed a duplicate table name.
Sun Jul 30 05:44:57 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.61: +1 -0 lines
Diff to previous 1.61 , to selected 1.84
Fixed a bug in the Family load.
Sun Jul 30 01:41:34 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.60 , to selected 1.84
Converted function name to a text field.
Sun Jul 30 01:18:54 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.59: +66 -0 lines
Diff to previous 1.59 , to selected 1.84
Sat Jul 29 17:38:47 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.58: +1 -1 lines
Diff to previous 1.58 , to selected 1.84
Fixed a bug in the synonym group loader.
Sun Jul 16 03:24:48 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.57: +2 -2 lines
Diff to previous 1.57 , to selected 1.84
Fixed to sort the incoming external data tables to remove duplicates.
Sat Jul 15 08:09:13 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.56: +32 -32 lines
Diff to previous 1.56 , to selected 1.84
Fixed bugs in the diagram and features loads.
Fri Jul 14 01:37:07 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.55: +94 -69 lines
Diff to previous 1.55 , to selected 1.84
Fixed Feature and SynonymGroup loads to no longer count on the output sort to remove duplicate keys.
Thu Jul 13 10:03:24 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.54: +3 -3 lines
Diff to previous 1.54 , to selected 1.84
Changed to load usable subsystems instead of NMPDR subsystems.
Thu Jul 13 08:47:34 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.53: +2 -0 lines
Diff to previous 1.53 , to selected 1.84
Added tracing.
Mon Jul 10 21:55:06 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.52: +0 -2 lines
Diff to previous 1.52 , to selected 1.84
Removed some trace messages.
Mon Jul 10 21:34:11 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.51: +1 -0 lines
Diff to previous 1.51 , to selected 1.84
Mon Jul 10 21:12:51 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.50: +1 -0 lines
Diff to previous 1.50 , to selected 1.84
Added more tracing.
Sun Jul 9 21:16:47 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.49: +8 -6 lines
Diff to previous 1.49 , to selected 1.84
Converted the PCH keys to integers.
Fri Jul 7 00:30:04 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.48: +0 -1 lines
Diff to previous 1.48 , to selected 1.84
Fri Jul 7 00:24:16 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.47: +22 -10 lines
Diff to previous 1.47 , to selected 1.84
Fixed to close all the load files before attempting to load the database.
Fri Jun 30 18:31:34 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.46: +1 -1 lines
Diff to previous 1.46 , to selected 1.84
Converted the coupling ID from a hash-string to an ID-string and fixed some call signatures.
Mon Jun 26 19:13:16 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.45: +6 -0 lines
Diff to previous 1.45 , to selected 1.84
Added support for subsystem classifications.
Sun Jun 25 07:53:37 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.44: +2 -2 lines
Diff to previous 1.44 , to selected 1.84
Sun Jun 25 07:51:04 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.43: +3 -1 lines
Diff to previous 1.43 , to selected 1.84
Sun Jun 25 07:34:46 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.42: +65 -0 lines
Diff to previous 1.42 , to selected 1.84
Sun Jun 18 05:49:28 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.41: +1 -1 lines
Diff to previous 1.41 , to selected 1.84
Fixed a comment.
Thu Jun 8 19:43:34 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.40: +2 -2 lines
Diff to previous 1.40 , to selected 1.84
Changed the subsystem load to reduce duplicate pegs in the cluster list.
Thu Jun 8 15:37:32 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.39: +0 -2 lines
Diff to previous 1.39 , to selected 1.84
Thu Jun 8 15:34:53 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.38: +1 -1 lines
Diff to previous 1.38 , to selected 1.84
Fixed an error in the retrieval of the ERDB object.
Thu Jun 8 15:12:55 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.37: +3 -3 lines
Diff to previous 1.37 , to selected 1.84
Fixed a bug that was causing real annotations to be thrown out as duplicates.
Sat May 27 02:01:24 2006 UTC (13 years, 6 months ago) by parrello
Diff to previous 1.36 , to selected 1.84
Fixed to remove deleted features from spreadsheet cells.
Fri May 19 07:26:17 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.35: +37 -39 lines
Diff to previous 1.35 , to selected 1.84
Changed the annotation loader to read the flat file instead of the database.
Mon May 15 20:00:54 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.34: +59 -53 lines
Diff to previous 1.34 , to selected 1.84
Fixed to skip all access to FIG data when loadOnly is specified.
Sat May 13 04:13:24 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.33: +3 -2 lines
Diff to previous 1.33 , to selected 1.84
Updated the comments.
Sat May 13 04:11:23 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.32: +8 -2 lines
Diff to previous 1.32 , to selected 1.84
Fixed to only include NMPDR subsystems.
Sun Apr 2 17:34:44 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.31: +2 -2 lines
Diff to previous 1.31 , to selected 1.84
Sun Apr 2 16:57:40 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.30: +142 -139 lines
Diff to previous 1.30 , to selected 1.84
Fixed subsystem load to recover if the subsystem is bad.
Sun Mar 26 12:35:21 2006 UTC (13 years, 8 months ago) by parrello
Diff to previous 1.29 , to selected 1.84
Added a relationship between Feature and Genome.
Mon Mar 13 19:19:37 2006 UTC (13 years, 9 months ago) by parrello
Diff to previous 1.28 , to selected 1.84
Fixed role subset bug.
Mon Feb 13 09:32:58 2006 UTC (13 years, 10 months ago) by parrello
Diff to previous 1.27 , to selected 1.84
Updated to remove taxon ID from the strain field.
Mon Jan 30 22:00:04 2006 UTC (13 years, 10 months ago) by parrello
Diff to previous 1.26 , to selected 1.84
Mon Jan 30 21:57:02 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.25: +17 -11 lines
Diff to previous 1.25 , to selected 1.84
Mon Jan 30 21:52:29 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.24: +58 -48 lines
Diff to previous 1.24 , to selected 1.84
Tue Jan 17 01:10:54 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.23: +11 -1 lines
Diff to previous 1.23 , to selected 1.84
Added better tracing to the property loader.
Fri Jan 13 06:59:49 2006 UTC (13 years, 11 months ago) by parrello
Changes since 1.22: +645 -618 lines
Diff to previous 1.22 , to selected 1.84
Mon Dec 12 21:48:22 2005 UTC (14 years ago) by parrello
Changes since 1.21: +1 -16 lines
Diff to previous 1.21 , to selected 1.84
Removed code for creating annotations out of functional assignments.
Sat Nov 12 03:42:48 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.20: +27 -59 lines
Diff to previous 1.20 , to selected 1.84
Wed Nov 2 21:54:40 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.19: +47 -55 lines
Diff to previous 1.19 , to selected 1.84
Moved the loading of reactions to the Reactions group.
Fixed Reaction and Compound loaders to load all reactions and subsystems rather than only those used in subsystems.
Fixed the Catalyzes loader to use the correct role ID.
Thu Oct 20 09:34:09 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.18: +16 -5 lines
Diff to previous 1.18 , to selected 1.84
Added the ability to load tables after generating the load files.
Added code to create the new RoleEC table.
Wed Oct 12 03:17:58 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.17: +254 -48 lines
Diff to previous 1.17 , to selected 1.84
Added load methods for the new subsystem-related tables.
Fixed annotations so the keys are unique without having to change the timestamps.
Added load methods for the reaction/compound tables.
Mon Sep 19 01:46:51 2005 UTC (14 years, 2 months ago) by parrello
Diff to previous 1.16 , to selected 1.84
Fixed an error in the Coupling data loader.
Fri Sep 16 10:31:15 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.15: +9 -4 lines
Diff to previous 1.15 , to selected 1.84
Fixed to handle sources without descriptions.
Fri Sep 16 04:12:05 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.14: +39 -37 lines
Diff to previous 1.14 , to selected 1.84
Fixed the subsystem load.
Fri Sep 16 02:38:49 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.13: +31 -33 lines
Diff to previous 1.13 , to selected 1.84
Fixed to iterate through the genomes used instead of the genomes returned by "subsystem_genomes"
Fri Sep 16 02:15:02 2005 UTC (14 years, 3 months ago) by parrello
Diff to previous 1.12 , to selected 1.84
Fri Sep 16 02:09:47 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.11: +7 -0 lines
Diff to previous 1.11 , to selected 1.84
Added more tracing.
Thu Sep 15 23:07:59 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.10: +7 -7 lines
Diff to previous 1.10 , to selected 1.84
Fixed to include external and internal aliases for features.
Wed Sep 14 11:40:17 2005 UTC (14 years, 3 months ago) by parrello
Diff to previous 1.9 , to selected 1.84
Wed Sep 14 11:21:24 2005 UTC (14 years, 3 months ago) by parrello
Diff to previous 1.8 , to selected 1.84
Wed Sep 14 09:57:27 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.7: +42 -28 lines
Diff to previous 1.7 , to selected 1.84
Tue Sep 13 19:05:20 2005 UTC (14 years, 3 months ago) by parrello
Diff to previous 1.6 , to selected 1.84
Fixed error in feature ID generation.
Sun Sep 11 17:09:46 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.5: +101 -8 lines
Diff to previous 1.5 , to selected 1.84
Fri Sep 9 14:55:01 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.4: +128 -0 lines
Diff to previous 1.4 , to selected 1.84
Tue Aug 16 20:35:03 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.3: +18 -15 lines
Diff to previous 1.3 , to selected 1.84
Fixed some bugs in the Genome load.
Sun Aug 14 23:53:25 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.2: +25 -21 lines
Diff to previous 1.2 , to selected 1.84
Fixed to work properly with the Unix PERL.
Sun Aug 14 23:47:16 2005 UTC (14 years, 4 months ago) by parrello
Diff to previous 1.1 , to selected 1.84
Added trace messages.
Sun Aug 14 23:32:09 2005 UTC (14 years, 4 months ago) by parrello
Diff to selected 1.84
